Not sure whether to post this in the DVD forum, or here, in graphics. It's kinda both. Even somewhat motherboards. Anyways, here is the problem. If I try to play a DVD, in any player, it freezes after a random amount of time. The entire system locks. Always random points and times of play. Wondering what could be causing this. I use a Radeon 9700 Pro on a Gigabyte GA-8INXP E7205 motherboard. As a side note, in the motherboard BIOS, if I enable the TOP PERFORMANCE option, I can't even complete a 3dMark test. It freezes. Last but not least, whenever I power off the computer, it powers itself right back on. Any clues to any of these problems would be greatly appreciated. Thanks.
Tech Support: "Hello, tech support, may I help you?"
Customer: (in a thick Russian accent) "Yes. Monitor is working fine but has sparks and smoke flying out back. Is ok?"
