Hey all,
I have three options for vid cards. I can't find anything on the GeForce 4 Ti 4800SE8X so any nfo or reviews on it that you could point me to would be great. I can save some cash going for one card or the other so base your opinions on that as well, thx.
The Cards:
<font color=blue>GeForce 4 Ti 4800SE8X - save $ 100 US
GAINWARD/CARDEXPERT GeForce 4 Ti 4800SE8X AGP, 3.6ns, Golden sample 128MB DDR.
1 DVI port + 1 CRT port + Video in and Video Out (VIVO) port + nVIEW (two CRT display) + 1 DVI to CRT adapter + 1 multiple cable + 1 CD driver + 1 manual, overclocking enhanced performance mode.
(Dual display), VG4UL7508X. OEM. Package content: 1 Gainward GeForce 4 Ti 4800 SE 128mb DDR graphic card + 1 DVI to CRT adapter + 1 multiple-port cable + 1 CD driver + 1 manual.
<font color=red>NOTE: Does this support DX 9?</font color=red>
v
ATI R 9700 Pro - save ($0 this is the base)
Sapphire ATI RADEON 9700 Atlantis PRO 128MB DDR,325/310, DVI/TV-out/CRT AGP BULK
Specifications:
Chipset:RADEON 9700Pro Visual processing unit (VPU)
Memory:128MB DDR, 256-bit memory
Eight parallel rendering pipelines
Four parallel geometry engines
Bus: AGP 8X support
Ports: VGA + DVI + S-Video Out
OS Support: Windows 98SE, Windows Me, Windows 2000, Windows XP
Powered by ATI, Manufactured by Sapphire
v
ATI R 9500 Pro - save $133 US
SAPPHIRE ATI OEM RADEON 9500 PRO 128MB DDR DVI BULK
Specifications:
Chipset:ATI RADEON 9500 PRO
Memory:128MB DDR
Bus:AGP 8X
128-bit floating-point color precision allows for a greater range of colors and brightness
Memory Bandwidth: 2GB/Sec
Directx 9.0 Supported
Supports Modes SmartShader2.0 SmoothVision2.0 Truform 2.0 and much more
Ports:VGA + DVI + Svideo Out (s-video cable included)
OEM Bulk Kit.
<font color=red> NOTE: Can you overclock this to Radeon 9700 Pro performance? Pls see Video Card topic:
</font color=red></font color=blue> Radeon 9500 Pro overclock to Radeon 9700 Pro?
Any opinions would be great, I would like to run with all visual options and filtering options on-Anisotropic, Anti-Aliasing(FSAA) etc-at highest settings, as some cards can outperform each other with certain options off though turning them on produces different comparisons, you guys know what I mean.
peace,
-=<font color=blue>i3lue}{orneT</font color=blue>=-
peace,
The Cards:
v
Specifications:
Bus: AGP 8X support
v
Specifications:
Memory:128MB DDR
Bus:AGP 8X
OEM Bulk Kit.
peace,
peace,
