hi,...i just got myself a sapphire 9700 Pro on my pc and was hoping that would pump up my Fps on Unreal 2, but i only got around 39fps on 1024x768 32 bit, Full detail(shadows etc) and without FSAA, Anistropic filtering, and the V-sync was off. So I was like "WAZZUP!?!?!" i'm pretty sure that my system is well above the reccomended one, any of u now what is wrong with it? Here is my system
P4 2,2Ghz 512cache(i think its called cache)
512Mb Pc 2100 DDR, ASUS P4BS533, Windows 98SE, Direct X 9 (already try with 8.1, upgrade to 9, no difference), Catalyst 3.0 (somehow i cannot installed the 3.1, it always said "fatal error" or somethin like that
i got 11K in my 3dmark 2001, on 1024x766, but when i try 1280x1024, the score lowered to around 6K. Something is wrong with my card or my system, could it be power supply?(only had 300w, but the system doesnt restar or crashes).
please help!!..i dont want to end up spend $320 on card that has the same performance as Ti4400.....thx
