Problems with the powering up of HP DV2500
  • Hewlett Packard
  • Thermal Compound
  • Power
  • Laptops
Last response: in Laptop Tech Support
December 20, 2011 10:07:57 PM
I repaired a hp dv2500 had no thermal paste on the cpu so i repaired that. I put it all back together no power, so i tried to break it down to a specific problem. If i don't put the top casing the one that the trackpad is imbedded into it will power on. Once i put the top casing back on with all the screws in. If doesn't power up. Nothing is touching the motherboard. So i am wondering if its not grounded right or something. Im out of options. I have narrowed it down to the top casing. Any suggestions. Thanks.
More about : problems powering dv2500
a b α HP
a b D Laptop
December 21, 2011 3:32:48 AM
Welcome to Tom's Hardware Forums!
You did well on the thermal paste! Check the ON switch for any interference preventing it from fully closing for startup.
m
l
December 21, 2011 3:54:42 AM
There's a slit in the aluminum so its not touching anything
m
l
December 21, 2011 7:06:25 PM
i dont know still no luck covered the bottom with electrical tape so it wouldnt touch motherboard u tighten one of the screws on the left side towards the power botton shuts off. nothing is touching the board. I have never experienced this problem before. Didn't think it would become such a hassle to put a laptop together and have this sort of issue.
m
l
