Turning off power saver feature on i7
Is it true the i7s power saver feature that shuts down 1/2 the processor cores has a way to shut the feature off? If so please share.
2 answers Last reply
More about turning power saver feature
  1. Control panel-system &security-power options and then you can select a power plan. I have not heard of Windows shutting down half the cpu cores to conserve power , I thought that was only controlled in the bios.
  2. The cores don't shut down. It goes to an idle state, which btw all cores can go in idle. There's no reason to turn it off unless you like more heat and power usage, it does not affect performance.
Intel i7 Processors Power Laptops
