Hi. I want to go and buy a 9700 pro video card and I know that it requires at least a 300w power supply. My computer is an HP, so i asked them if i could go to a local store and buy and install a bigger power supply. They responded with:
HP does not recommend that the power supply in any of its machines be changed or replaced. Changing the power supply could damage other system components.As per the product specifications of Pavilion 753n,the power supply present in your PC can support an input voltage of around 110V - 230V and has the maximum output voltage of 124W or 149W
Now is this true because the power supply is propietary? And if it is, there any way for me to use a 9700 Pro on my PC? Also, is my present Power suplly enough or do i still need a new one? Thanks in advance. I've asked at several different places, and then someone reccomended me to ask here.
