Dimension 8100 Memory Problem
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hi,
I have two identical Dimension 8100, Intel 850 - 400, 128 megs (2 x 64
megs rimms Samsung MR16R0824BN1-CK8 800-45).
The BIOS is the A09 (I run Win2K).
I've tried to upgrade the memory to 384 megs using a Kingston RIMM kit
(2 x 128 megs - KTD-DM800/128) but the system seems unable to see more
256 megs.
That's what the BIOS tell:
Slot 1: 64
Slot 2: 64
Slot 3: 64
Slot 4: 64
But the first pair of slots actually contains the two Kingston 128
Rimms and the second pair contains the two Samsung 64 Rimms.
The situation does not change if I put the Kingstons in the first pair
and two CRIMMS in the second pair: the system sees the two 128
Kingstons as if they were 64 megs RIMMS.
This happens with both my Dimension 8100.
Anybody?
Thanks
Filippo
11 answers Last reply
More about dimension 8100 memory problem
  1. Archived from groups: alt.sys.pc-clone.dell (More info?)
    <lippilippo@netscape.net> wrote in message
    news:1103458641.275905.281370@f14g2000cwb.googlegroups.com...
    > Hi,
    > 256 megs.
    > Slot 1: 64
    > Slot 2: 64
    > Slot 3: 64
    > Slot 4: 64
    > Anybody?
    > Thanks
    > Filippo
    Try http://www.tritechcoa.com/product/901824.html
    Uses ECC RDRAM
    Craig
  2. Archived from groups: alt.sys.pc-clone.dell (More info?)
    In news:1103458641.275905.281370@f14g2000cwb.googlegroups.com,
    lippilippo@netscape.net <lippilippo@netscape.net> opined very noisily:
    > Hi,
    > 256 megs.
    > Slot 1: 64
    > Slot 2: 64
    > Slot 3: 64
    > Slot 4: 64
    > Anybody?
    > Thanks
    > Filippo
    From
    http://www.crucial.com/store/listparts.asp?Mfr%2BProductline=Dell%2BDimension&mfr=Dell&cat=RAM&model=Dimension+8100+Series&submit=Go
    We're Sorry!
    No products are currently available for the system you selected. Your system
    may require proprietary or non-standard parts. If your system requires RDRAM
    or Rambus technology click here.
    Looks like you need expensive memory
    Yddap
    Remove guts to reply
  3. Archived from groups: alt.sys.pc-clone.dell (More info?)
    "Yddap" <yddap@spyentrailsmac.com> wrote in message
    news:Qtexd.2803$Ar5.2049@text.news.blueyonder.co.uk...
    >> Hi,
    >> 256 megs.
    >> Slot 1: 64
    >> Slot 2: 64
    >> Slot 3: 64
    >> Slot 4: 64
    >> Anybody?
    >> Thanks
    >> Filippo
    > From
    > We're Sorry!
    > system may require proprietary or non-standard parts. If your system
    > requires RDRAM or Rambus technology click here.
    > Yddap
    What was your point with this post? Crucial NEVER sold RDRam, as Micron
    never made it.
    Tom
  4. Archived from groups: alt.sys.pc-clone.dell (More info?)
    "Craig" <nospam_wanted@on_the_net.com> wrote in message
    news:NIfxd.15690$up.456@lakeread08...
    >> Hi,
    >> 256 megs.
    >> Slot 1: 64
    >> Slot 2: 64
    >> Slot 3: 64
    >> Slot 4: 64
    >> Anybody?
    >> Thanks
    >> Filippo
    > Uses ECC RDRAM
    > Craig
    The Dimension 8100? No, it doesn't. It supports both, but shipped with
    PC800 non-ECC.
    Tom
  5. Archived from groups: alt.sys.pc-clone.dell (More info?)
    "Tom Scales" <tomtoo@softhome.net> wrote in message
    news:Tfqdncb2yuz0UVjcRVn-3w@comcast.com...
    >>> Hi,
    >>> 256 megs.
    >>> Slot 1: 64
    >>> Slot 2: 64
    >>> Slot 3: 64
    >>> Slot 4: 64
    >>> Anybody?
    >>> Thanks
    >>> Filippo
    >> Uses ECC RDRAM
    >> Craig
    > PC800 non-ECC.
    > Tom
    Right it supports both...as per website it can also use ECC-RDRAM ..I did
    not say
    the DELL Dimension ships with this type of RAM. If one wants to use
    ECC-RDRAM
    in that computer a simple change in bios is all it takes.
    Craig
  6. Archived from groups: alt.sys.pc-clone.dell (More info?)
    >>> Hi,
    >>> 256 megs.
    >>> Slot 1: 64
    >>> Slot 2: 64
    >>> Slot 3: 64
    >>> Slot 4: 64
    >>> Anybody?
    >>> Thanks
    >>> Filippo
    >> Uses ECC RDRAM
    >> Craig
    > PC800 non-ECC.
    > Tom
    For both NON-ECC and ECC RDRAM try here
    http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=17280
    Craig
  7. Archived from groups: alt.sys.pc-clone.dell (More info?)
    news:rckxd.16341$up.10522@lakeread08...
    >>>> Hi,
    >>>> 256 megs.
    >>>> Slot 1: 64
    >>>> Slot 2: 64
    >>>> Slot 3: 64
    >>>> Slot 4: 64
    >>>> Anybody?
    >>>> Thanks
    >>>> Filippo
    >>> Uses ECC RDRAM
    >>> Craig
    >> PC800 non-ECC.
    >> Tom
    > not say
    > ECC-RDRAM
    > Craig
    I suppose, but if he is upgrading, a recommendation for memory that matches
    what is in his computer makes more sense.
  8. Archived from groups: alt.sys.pc-clone.dell (More info?)
    Thanks to everybody!
    >From your replies it seems that the problem is that the Kingston RIMMS
    DON'T work. Is this a well known fact? I bought two pairs of Kingston
    RIMMS from their web site some years ago (I used the configurator and
    they sold them as compatible with Dimension 8100).
    Also I thought that the problem could be related to the BIOS. I've
    found what follows on the Dell web site:
    =-> In order to upgrade, the customer must remove all existing system
    memory and replace completely. To upgrade the memory, a BIOS update is
    required. The latest BIOS revision and instructions on how to flash
    update the BIOS are located at www.support.dell.com <-=
    (http://accessories.us.dell.com/sna/ProductDetail.aspx?c=us&l=en&cs=19&sku=A0276516&category_id=4325)
    What does this mean? If you don't upgrade the BIOS the systems won't
    see the new RIMMS?
    Finally, do you have direct experience of the RIMMS you pointed me to
    and know that they actually work?
    Thanks again
    Filippo
  9. Archived from groups: alt.sys.pc-clone.dell (More info?)
    I bought my two Dimension 8100 both with the standard configuration of
    128 Megs (2x64 Samsung RIMMS).
    Then I bought 2 Kingston kits 2x128 Rimms each.
    The idea was to mount the two Kingston kits in one of the Dimension
    8100 (for a total of 512 Megs) and put the four 64 megs modules in the
    other Dimension 8100 (total of 256 Megs).
    I've upgraded the BIOS to the latest suggested release for Win2K (A09).
    Any idea?
  10. Archived from groups: alt.sys.pc-clone.dell (More info?)
    Wow! The information quoted on the Dell web site is dis-information, unless
    there is somehow a strange BIOS limitation that prohibits the BIOS from seeing
    more memory. Or maybe I don't understand the context of the quoted info.
    "In order to upgrade, the customer must remove all existing system memory and
    replace completely." I can come up with lots of examples with RAMBUS memory
    where this would not be the case. It all depends on the original configuration
    and the desired memory configuration... Ben Myers
    >see the new RIMMS?
    >Thanks again
    >Filippo
  11. Archived from groups: alt.sys.pc-clone.dell (More info?)
    I've not run into problems using Kingston RIMMs in Dells and other brands of
    computers with RAMBUS memory. All I can suggest at this point is that you may
    have defective Kingston memory. Can you return it for a refund?
    .... Ben Myers
    >Any idea?
Dell Kingston Memory Dimension Samsung Computers
