Yes No
Ads
Tom's Hardware > Forum > Laptops & Notebooks > Acer > [Solved] Acer netbook battery light flashes 5 times and nothing happens
Forum Laptops & Notebooks : Acer [Solved] Acer netbook battery light flashes 5 times and nothing happens
Best answer from hang-the-9.
acers aspire one....D257 i left it charging for the afternoon , came back and it was off . i went to start it with the start button and nothing. the little battery icon on the front of the key board flashes 5times red or orange every time i push the start button. i read the instruction on residual discharge of power , take the battery out and unplug it and hold the power button down for 30 sec....nothing changed after i restored the battery and A/C power. how do i test the battery or the charger? how do i order new ones if i need them? :bounce: :bounce: :o
Reply to thomas chavers
Best answer
Try to run without the battery, just on wall power.
Cheapest thing to try is a new power brick. Then you are looking into having someone check the power connection and maybe replacing the motherboard. On a netbook, probably not worth it, can get a new one for about the same cost. Unless it's a power plug issue, but you could end up spending money to try to fix it and that's not the issue.
------------------------------ Recommended Video Cards: http://www.tomshardware.com/review [...] ,3085.html
Reply to hang-the-9
Need clarification, is the laptop running now. So you left it charging you came back and it doesn't run now and the battery light flashes 5 times?
Reply to captjack5169
thank you guys for the ideas...i replaced the power brick as you call it and it started right up....i found a used one in some old junk and it was the same out put and npn or pnp..i cannot remember...but the stats. were +/- 10% so it works...hurraayy!!!!
There are 2136 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Upgrading lapptop
By jaguarskx, 2 hours ago:
The Radeon HD 7450m is an entry level card. It is better than the Intel HD 3000 graphic...
Best offers
Top experts
