Replacement battery for Packard Bell TJ61
Looking for a decently priced (under £50) battery that isn't the Chinese "going to die in a year" type. Looked everywhere and even Amazon resellers are Chinese companies so pretty stuck. Battery model is AS09A75. Please help!!!
1 answer Last reply
More about replacement battery packard bell tj61
  1. Check here http://store.packardbell.com/store/pbemea/en_GB/list/parentCategoryID.52229800/categoryID.52230100
    If you want something cheaper than what they have there, it will be an after market one which you don't want to get. If ebay or Amazon does not have any real OEM products, either get from packard bell directly or hope the cheap ones last.
Battery Packard Bell Amazon Laptops
