Archived from groups: alt.sys.pc-clone.dell (More info?)
When I tried to loan XP Home SP1, the computer (Dimension 4400) froze on
boot so I went reloaded XP Home. Now when I tried SP2 I get the same thing,
what a surprise. The screen says to check for memory problems with the
utility disk. I can't seem to get the utility disk to run or access it.
Anyone know how to do this?
So I'm going to try to replace the memory. Question is I have DDR266
running. Will any DDR work, like Kinston 2100 or 2700 DDR?
You need to buy the correct RAM for your computer. The better quality RAM
vendors will help you select the exact RAM that you need. For example:
Crucial (www.crucial.com) manufactures top quality RAM and has a RAM
selector. Windows XP works best with 512MB of RAM.
Ted Zieglar
"Jeff Berk" <berk@brodskyberk.com> wrote in message
news:9M2dnX00ULZrvFfcRVn-tg@comcast.com...
> thing,
> Thanks
> Jeff
> thing,
> Thanks
> Jeff
Jeff -
So no luck attempting to boot to the (Dell) resource CD to run the extended
system diags?
I had a Gateway 500S of the same general (chipset/CPU/RAM) type that
absolutely refused to accept an SP2 install w/o major problems...
Thanks guys.
It won't boot from the diag cd. SP1 wouldn't load either. Thing is my
warranty expires in 20 days.
"S.Lewis" <stew1960@cover.bellsouth.net> wrote in message
news:Ssqyd.4911$wZ1.726@bignews3.bellsouth.net...
> > thing,
> > Thanks
> > Jeff
> Jeff -
extended
> system diags?
> Stew
Oh! This is a Dell computer under warranty, and the memory that gives XP a hard
time is original from Dell? That's good reason to get warranty service on the
computer. What is/was the original operating system?
You could also run either MEMTEST-86 or MEMTEST-86+ to test the memory in the
computer. If either one shows errors, then the memory is bad, or there is a
serious problem with the motherboard... Ben Myers
On Wed, 22 Dec 2004 22:17:14 -0500, "Jeff Berk" <berk@brodskyberk.com> wrote:
>Thanks guys.
>> > thing,
>> > Thanks
>> > Jeff
>> Jeff -
>extended
>> system diags?
>> Stew
On Wed, 22 Dec 2004 20:39:36 -0500, "Jeff Berk" <berk@brodskyberk.com>
I wouldn't do this until I know for sure it's bad. Get yourself a
copy of one of the Memtest programs and let it run overnight
exercising the memory in the machine. If it comes up clean, you do
not have a memory problem and replacing it isn't going to make SP2
load.
I have found through quite a few painful experiences that your chances
of getting a good working installation of SP2 are *vastly* improved if
you reinstall (or do a repair install of) XP using a slipstreamed SP2
disk. You can make yourself one of those using Autostreamer. Google
it for what you need to know to use it.
news:hsqdnRZFt_BApVfcRVn-oA@comcast.com...
> Thanks guys.
<snip>
I'd have a hard look at both the RAM and hard disk.
I believe the 4400 can run the quick HDD diags (CTL+ALT+D at the dell splash
screen) which might be worth the 5 mins. it would take to check it.
If I had two sticks of RAM in the machine, I'd try reseating both (then try
again) and then try one DIMM at a time (if this applies).
I'd also make sure the machine has no externals connected to it other than
the monitor, keyboard, and mouse during the install.
If you can't make progress after any of this (running system diags would be
a big help), then I'd call Dell pronto since you're still under warranty.
Something which I ran into when I installed additional DDR into my 8300 was
the fact that I thought I had really seated the old memory chips in their
new locations, but only one end was properly seated and the other was not on
one of the chips. It booted up, but I did get an error and when I checked
on the memory under System that is where I saw that something was amiss. I
reopened the clamshell style of the 8300 and pushed on all the memory until
I saw that the one in Bank number 2 was not seated properly. The clip
engaged the slot fully and that was what made the difference in operation.
> Thanks guys.
So for what it's worth, the computer got clobbered when I tried to go back
to XP. With the fresh install, the upgrade went fine. There was no problem
with the memory, video card or anything else except Windows, the devil
incarnate.
Jeff
thing,
> Thanks
> Jeff
