Help....its urgent
Last response: in Laptops & Notebooks
January 26, 2012 7:06:13 AM
Hello, i have toshiba satellite laptop. whenever i plug charger to my laptop, it hangs & then i have to press the power button to shut it down. i can work on my laptop only when its not plugged for charging. please provide me with a solution...
More about : urgent
a c 572 D Laptop
January 26, 2012 9:56:12 AM
Hello shikha_lcs;
I don't know what the problem is so a solution might be wishful thinking.
Will your laptop run on AC power with the battery removed?
a c 572 D Laptop
January 26, 2012 9:56:47 AM
Can you explain why this is urgent?
It sounds to me like your laptop is working normally on the battery.
January 27, 2012 2:36:12 AM
i can't work on my laptop with its charging on... i have project to do for that i need to work on laptop all the tym... this problem is is causing me lots of trouble.. i have to fully charge my lappy so that i get complete 2 hrs to work...then again charge for 2 hrs...
trust me its not a gud feeling...!!!!!
January 27, 2012 3:00:11 AM
try removing the battery and running it off mains alone.
what model is it, how old?
it could be a faulty battery.
January 27, 2012 8:25:02 AM
its toshiba satellite a200... bought in 2007...
can u help me..?
