Acer aspire 6920g does not work without battery
Hello,
Help, my acer doesnt not work plugged in without battery, and the blue led light keeps flashing and making a weird ticking sound like a clock. Could this be recharger problem? because when i plug it out the computer shuts down and it doesnt work without the plugger. If i take the battery out and plug in the recharger it still doesnt turn on and makes that weird ticking sound. Please help, my laptop is about to discharge the battery
1 answer Last reply
More about acer aspire 6920g work battery
  1. you got same problem as me i think. basicly if you unscrew the bit where the power adapter goes you will see a loose wire mine came off so i taped them back on and its been fine ever since. darkforce1983@gmail.com
    xxwhatever said:
    Hello,
Acer Battery Aspire Laptops
