Problem Description:
HI,
I have a problem capturing audio using the ATI MediaCentre 8.5 PVR, I've checked all my connections and I can watch media files,TV,DVD, CD's etc with no problems. I haved used the 'initialisation wizard' but when I select the 'Line Input'option then click 'Next' it keeps switching to the 'Mic Input' option for audio recording. I am using XP Pro (SP1), i've been into the control panels and checked the correct recording source is selected and the level is turned up. I've been to the ATI site and installed the Catalyst 3.4 suite (i followed the installation instructions to the letter). I have Directx 9.0a & Media Encoder 7.01.00.3055 installed. But still no joy, could anyone help please i've been trying to get this to work for the last 3 days now. Many Thanks.
Kind Regards
Dean
SYSTEM INFORMATION:
Machine Brand: Asus
Machine Model: A7V8X
CPU Type: AMD Athlon(TM) XP 2400+
CPU Speed (MHz): 2000 MHz
Chipset Vendor ID Not Detected
Chipset Device ID Not Detected
Chipset Revision Not Detected
[Enum\Root\*PNP0C01\]
============================O/S INFORMATION============================
Windows XP -- 5.01.2600 Service Pack 1
DirectX Version 09.00.0901
======================DISPLAY ADAPTER INFORMATION======================
PCB P/N:
Upgrade Module P/N:
RV250
ASIC
Card Manufacturer = ATI Technologies Inc.
Type = RV250
Bus Type = AGP
I/O Type = Relocatable
I/O Base Address = D800h
Aperture Configuration = 64 MB
Aperture Range = 4 G
Aperture Address = F4000000h
Register Aperture Address = EB000000h
VGA Disabled = No
VGA Boundary = Full Access
2D Acceleration = Yes
3D Acceleration = Yes
Motion Compensation = Yes
IDCT Acceleration = Yes
Bus Mastering = Yes
AGP Transfer Supported = AGP 1X, AGP 2X, AGP 4X
Current AGP Transfer Mode = AGP 1X, AGP 2X, AGP 4X
PCI Configuration
Device ID = 4966
Vendor ID = 1002
Revision = 1
Bus Number = 1
Device Number = 0
Function Number = 0
Subsystem ID = 4F72
Subsystem Vendor ID = 1002
Primary Display Device = Yes
Memory
Type = DDR SGRAM / SDRAM
Size = 64 MB
Frequency = Not Detected
Block Write Support = Yes
BIOS
Version = 8.004
Date = 2002/08/23
Part Number = 113-95902-100
DDC Detected = Not Detected
DDC Support = Not Detected
Video In
Chip Type = Rage Theater
Standard = PAL
Connector = Not Detected
I2C Address = 88h
Tuner
Type = Philips FQ1216ME/P PAL I/B/G/D/K SECAM D/K
/L
Standard = PAL, SECAM
I2C Address = C6h
Power Down Support = No
Multimedia
I2C Type = Dedicated I2C Pin
All-In-Wonder Family = Yes
I/O Expander = No
I/O Expander Address = Not Detected
I/O Expander Value = Not Detected
RV250
ASIC
Type = RV250
Bus Type = PCI
I/O Type = Sparse
I/O Base Address = Not Detected
Aperture Address = EC000000h
Register Aperture Address = EA800000h
VGA Disabled = Yes
VGA Boundary = No Access Through VGA
Bus Mastering = Yes
AGP Transfer Supported = Not Detected
Current AGP Transfer Mode = Not Detected
PCI Configuration
Device ID = 496e
Vendor ID = 1002
Revision = 1
Bus Number = 1
Device Number = 0
Function Number = 1
Subsystem ID = 4F73
Primary Display Device = No
Memory
Size = 64 MB
BIOS
Version = 8.004
Date = 2002/08/23
Video In
Chip Type = BT819
Standard = Not Detected
I2C Address = 88h
Multimedia
All-In-Wonder Family = No
I/O Expander = No
======================DISPLAY DRIVER INFORMATION=======================
ALL-IN-WONDER 9000
7.88-030430m-008946C-ATI
C:\WINDOWS\System32\Drivers\ati2mtag.sys
Version = 6.14.10.6343 Size = 625920 bytes
C:\WINDOWS\System32\ati2dvag.dll
Version = 6.14.10.6343 Size = 291584 bytes
C:\WINDOWS\System32\ati3d1ag.dll
Version = 6.14.10.3777 Size = 912056 bytes
C:\WINDOWS\System32\ati3d2ag.dll
Version = 6.14.10.3777 Size = 1122808 bytes
C:\WINDOWS\System32\ati3duag.dll
Version = 6.14.10.168 Size = 851345 bytes
C:\WINDOWS\System32\ATIDDC.DLL
Version = 5.13.1.3 Size = 49152 bytes
C:\WINDOWS\System32\atitvo32.dll
Version = 6.14.10.3003 Size = 32768 bytes
C:\WINDOWS\System32\ativcoxx.dll
Version = 6.13.10.5 Size = 24064 bytes
C:\WINDOWS\System32\ati2evxx.dll
Version = 6.14.10.4073 Size = 69632 bytes
C:\WINDOWS\System32\atipdlxx.dll
Version = 6.14.10.2479 Size = 77824 bytes
C:\WINDOWS\System32\Oemdspif.dll
Version = 6.14.1.8 Size = 73728 bytes
C:\WINDOWS\System32\atioglxx.dll
Version = 6.14.10.3717 Size = 5165133 bytes
C:\WINDOWS\System32\atiiiexx.dll
Version = 6.14.10.3007 Size = 290816 bytes
ALL-IN-WONDER 9000 - Secondary
=================================FILES=================================
%%%%%%%%%%C:\AUTOEXEC.BAT%%%%%%%%%%
%%%%%%%%%%C:\CONFIG.SYS%%%%%%%%%%
%%%%%%%%%%SYSTEM.INI%%%%%%%%%%
; for 16-bit app support
[drivers]
wave=mmdrv.dll
timer=timer.drv
[mci]
[driver32]
[386enh]
woafont=app850.FON
EGA80WOA.FON=EGA80850.FON
EGA40WOA.FON=EGA40850.FON
CGA80WOA.FON=CGA80850.FON
CGA40WOA.FON=CGA40850.FON
%%%%%%%%%%WIN.INI%%%%%%%%%%
[fonts]
[extensions]
[mci extensions]
[files]
[Mail]
MAPI=1
[MCI Extensions.BAK]
aif=MPEGVideo
aifc=MPEGVideo
aiff=MPEGVideo
asf=MPEGVideo2
asx=MPEGVideo2
au=MPEGVideo
m1v=MPEGVideo
m3u=MPEGVideo2
mp2=MPEGVideo
mp2v=MPEGVideo
mp3=MPEGVideo2
mpa=MPEGVideo
mpe=MPEGVideo
mpeg=MPEGVideo
mpg=MPEGVideo
mpv2=MPEGVideo
snd=MPEGVideo
wax=MPEGVideo2
wm=MPEGVideo2
wma=MPEGVideo2
wmv=MPEGVideo2
wmx=MPEGVideo2
wvx=MPEGVideo2
wpl=MPEGVideo
[WAOL]
AppPath=C:\Program Files\AOL 7.0
SharedPath=C:\Program Files\Common Files\AOLSHARE
[programs]
HI,
Kind Regards
Dean
SYSTEM INFORMATION:
Machine Brand: Asus
PCB P/N:
Upgrade Module P/N:
RV250
ASIC
Type = RV250
Bus Type = AGP
VGA Disabled = No
Bus Mastering = Yes
PCI Configuration
Device ID = 4966
Vendor ID = 1002
Revision = 1
Bus Number = 1
Device Number = 0
Function Number = 0
Subsystem ID = 4F72
Memory
Size = 64 MB
BIOS
Version = 8.004
Date = 2002/08/23
Video In
Standard = PAL
I2C Address = 88h
Tuner
/L
I2C Address = C6h
Multimedia
I/O Expander = No
RV250
ASIC
Type = RV250
Bus Type = PCI
I/O Type = Sparse
VGA Disabled = Yes
Bus Mastering = Yes
PCI Configuration
Device ID = 496e
Vendor ID = 1002
Revision = 1
Bus Number = 1
Device Number = 0
Function Number = 1
Subsystem ID = 4F73
Memory
Size = 64 MB
BIOS
Version = 8.004
Date = 2002/08/23
Video In
Chip Type = BT819
I2C Address = 88h
Multimedia
I/O Expander = No
ALL-IN-WONDER 9000
[drivers]
wave=mmdrv.dll
timer=timer.drv
[mci]
[driver32]
[386enh]
woafont=app850.FON
[fonts]
[extensions]
[mci extensions]
[files]
[Mail]
MAPI=1
aif=MPEGVideo
aifc=MPEGVideo
aiff=MPEGVideo
asf=MPEGVideo2
asx=MPEGVideo2
au=MPEGVideo
m1v=MPEGVideo
m3u=MPEGVideo2
mp2=MPEGVideo
mp2v=MPEGVideo
mp3=MPEGVideo2
mpa=MPEGVideo
mpe=MPEGVideo
mpeg=MPEGVideo
mpg=MPEGVideo
mpv2=MPEGVideo
snd=MPEGVideo
wax=MPEGVideo2
wm=MPEGVideo2
wma=MPEGVideo2
wmv=MPEGVideo2
wmx=MPEGVideo2
wvx=MPEGVideo2
wpl=MPEGVideo
[WAOL]
[programs]
