MSI GX660R battery charger failure? Or charging port failure? :S
lilpopjim
167
Hi.
Long story short, the battery charger for my MSI GX660R Gamming Laptop's charger has started to fall on me.
It will only charge if i wiggle the charger connector, and constantly realign the male connector, with out that external 'influence' the laptop will fail to charge. So in it's present state, i can't use the laptop it's self as it can't receive a charge. Thus making it useless!
Everything is under warrenty as well. I've had the laptop little under 9 months.
I don't know weather if it's the charging port on the laptop It's self which will need replacing. Or if i can go out and buy another charger with the same Ampage and Voltage giving it the same power output rating.
I want to sell my laptop also. If i RMA it it may take sometime to deliver, get fixed, then ship back etc. and i'm going to New York for a week in 2 weeks so i want to get it sorted by then as i'm planning on purchasing an ASUS Transformer Prime before i go as i barely use the laptop as it is.
So is it the Port in the laptop. Or the charger :S Shall i file for an RMA? Or buy a new charger?
Thanks for anyhelp in advanced! Lewis.
