The problem i have is with Direct X.
Both Direct Draw and Direct 3D do not work properly under DXdiag.
Here is what i have done to try and rectify the problem so far:
1.Reformatted the Hard Drive.
2.Installed Windows XP - installs DX 8.1 itself.
3.Installed the latest Detonator drivers.
4.Everything works fine except Direct X applications.
I found an error report that basically said:
Driver file "nv4_disp.dll" was stuck in a continous loop.
This is a main driver file.
Here is the technical report:
Quote:
szAppName : Drivers.Display szAppVer : 10DE0250A280131043
szModName : nv4_disp.dll szModVer : 6.13.10.2832 Offset : 782506EA
F:\WINDOWS\LogFiles\Watchdog\030609_0142_01.wdl
// Watchdog Event Log File
LogType: Watchdog
Created: 2003-06-09 01:42:56
TimeZone: 0 - GMT Standard Time
WindowsVersion: XP
EventType: 0xEA - Thread Stuck in Device Driver
// The driver for the display device got stuck in an infinite loop. This
// usually indicates a problem with the device itself or with the device
// driver programming the hardware incorrectly. Please check with your
// display device vendor for any driver updates.
ShutdownCount: 3
Shutdown: 0
EventFlag: 1
EventCount: 1
BreakCount: 1
BugcheckTriggered: 1
DebuggerNotPresent: 1
DriverName: nv4_disp
DeviceClass: Display
DeviceDescription: ASUS V8460 ULTRA DELUXE v28.32b
HardwareID: PCI\VEN_10DE&DEV_0250&SUBSYS_80131043&REV_A2
Manufacturer: ASUSTek
DriverFixedFileInfo: FEEF04BD 00010000 0006000D 000A0B10 0006000D 000A0B10 0000003F 00000008 00040004 00000003 00000005 00000000 00000000
DriverCompanyName: ASUSTeK Computer Inc.
DriverFileDescription: ASUS nVidia Series Windows 2000/XP Display Driver, Version 28.32
DriverFileVersion: 6.13.10.2832
DriverInternalName: nv4_disp.dll
DriverLegalCopyright: Copyright (C) ASUSTek Computer Inc.1994-2001
DriverOriginalFilename: nv4_disp.dll
DriverProductName: ASUS nVidia Series Windows 2000/XP Display Driver, Version 28.32
DriverProductVersion: 6.13.10.2832
This was happening BEFORE i formatted and re-installed Windows.
Tried re-installing both Nvidia drivers and the ASUS ones - problem still occurs.
Having reformatted with a fresh Windows XP Pro install and fresh drivers...
Problem with the card itself?
ASUS GF 4 TI 4600
Any help or info would be GREATLY appreciated!
Thanks!
Laters!
