Yes No
Ads
Tom's Hardware > Forum > Laptops & Notebooks > General Discussion > Gateway ma7 wont start, battery and charger works
Forum Laptops & Notebooks : General Discussion Gateway ma7 wont start, battery and charger works
HI,
I have a Gateway MA7 model MX6931 and this is what happened:
I used the laptop the night before and everything was ok, but the next morning when I was going to use it... didn't turn on!
I can see that the laptop is getting power from the battery and it also charges the battery if its low in charge, so I don't think its the battery or the charger.
I can see that the battery LED is lit up and blue (not red, or flashing), but when I hit the power button, the front power LED lits up for a sec and then dims out but nothing gets powered, the fan does not move, no other LED lits up... nothing.
I have tried to start it with and without the charger, with or without the battery and nothing... just the power LED lighting up and dimming out after a sec.
Does anyone have an Idea of what it could be?
Thanks in advance.
Oscar
Reply to chronoss
Try a different charger. Since you said you tried without the battery, can rule that out. Could be the power leads, motherboard also. RAM maybe. If you have a couple of RAM sticks, try using them one at a time see if it boots.
------------------------------ Recommended Video Cards: http://www.tomshardware.com/review [...] ,3085.html
Reply to hang-the-9
Thank you for your reply,
I tried with a different gateway charger and different ram sticks (for the same model), unfortunately I am still unable to get it to boot :(
Reply to chronoss
Need to start looking at the power jack and maybe the motherboard. Looks like that laptop is 5 or so years old, may not be worth it to repair. Will cost a few 100 in labor and parts, you can get a new laptop for about $400, or a used faster one for 2-300.
Reply to hang-the-9
If you tried different charges and even tried different RAM sticks and still the laptop won't turn on, take to a lab - it might not be so costly..
Reply to fortuna
There are 2112 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Upgrading lapptop
By jaguarskx, 2 hours ago:
The Radeon HD 7450m is an entry level card. It is better than the Intel HD 3000 graphic...
Best offers
Top experts
