Yes No
Ads
Tom's Hardware > Forum > Laptops & Notebooks > Acer > Why won't laptop recognize the battery ??
Forum Laptops & Notebooks : Acer Why won't laptop recognize the battery ??
I have put a new battery in my laptop and it will not recognize it.
Reply to freddie1
Reply to freddie1
I might be an issue with your new battery. Does it recognize the old one at all?
It might be a software issue as well. Can you clean install?
Reply to sardonicone
yes it recognized the old battery and did this one when i first put it in,then when I plugged it in it would not recognize it
Reply to freddie1
When the laptop is plugged in it will not show it charging except the light will blink until it is charged. Is the laptop battery charging at all? Go to the battery section and select to show desktop icon when connected select them both. If your not charging then it is another matter. Download the driver for the battery at your computer support pages under drivers and downloads, etc, If it does take a charge the set the mode to see on system tray for the battery.
Reply to jcrowder0027
Hi :)
WHICH laptop ?
All the best Brett :)
Reply to Brett928S2
Some laptops have built in chips to only allow oem batterys so you cant use cheap replacements.
Reply to daship
There are 2161 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Upgrading lapptop
By jaguarskx, 2 hours ago:
The Radeon HD 7450m is an entry level card. It is better than the Intel HD 3000 graphic...
Best offers
Top experts
