help,choosing videocard
help me choose video card please
my comp:
-p iv 1.6
-ddr pc 2700 512 x 2
-mb msi 655 ls
-hd 40 gb 7200rpm
i use:
-autocad
-3ds max
-c&c the generals
and the budget : $100-$150
any suggestion ?
thanks
10 answers Last reply
More about help choosing videocard
  1. Its up to you, but I would consider...
    VGA CHAINTECH GEFORCE4 TI4800SE128MB VGA & TV-OUT, DVI OUT
    $141 @ newegg
    or
    POWERCOLOR ATI RADEON 9500 128MB DDR 8X AGP
    $142 @ newegg
    or
    MSI G4Ti4200-TD (8870-040) GF4 TI4200 128MB 128bit TV-OUT DVI VGA Card
    $121 @ newegg
  2. into that list i'd toss a:
    Gainward FX PowerPack! Ultra/760 TV/DVI GeForce FX 5600 AGP 8X 128MB DDR w/TV-Out & DVI Retail $135 @ gameve.com/pricewatch
    Shadus
  3. Humm... You should check benchmark on Tom's... I think a GeForce would offer better performance in CAD than ATI... But, not sure!
    Check through the articles!
    Would you buy a GPS enabled soap bar?
  4. Yes, Nvidia's drivers perform much better than Ati's for professional cad work.
    Radeon 9500 w/256 bit memory bus @ 367/310
    AMD AthlonXP 2000+
    3dMark03: 3439
  5. One thing to consider about the ATI is that I believe it would offer better performance in DirectX9 games (right?). Also, ATI tends to produce better image quality. For current games, a 9500 nonpro would probably not beat some of those NVidia cards. Check out the benchmarks here:
    http://www.tomshardware.com/graphic/20030120/index.html
  6. But as "watten" specified in his post. He seems to do more CAD than gaming. And GeForce drivers gives better performance in CAD software.
    I I was him, I would consider the GeForce for better CAD and I would sacrifice some quality and performance in games.
    Anyway, if you chekc is system SPEC he would not see much difference between ATI/GeForce in game performance.
  7. A 9500 non-pro is pretty much exactly on par with the Ti4200, beating it with AA and ansio enabled but losing slightly with them disabled.
    You really can't lose with any of those Geforce4's, especially if you're also doing cad work.
    AMD AthlonXP 2000+
    3dMark03: 3439
  8. besides..... you can always softmod your GF4 into a Quadro :)
    Proud Owner the Block Heater
    120% MATROX/INTEL EXTREME GRAPHICS Fanboy
  9. Dont start again with that Soft-Quadro crap. I can here Flamethrower running down the hall already....
    Please refrain from personal attacks of other users and the use of foul language or you'll be banned. Last warning. - Fredi
  10. what is softmod ??
    well, should i buy ti 4200 or fx 5600 ?
    thanks
Graphics Cards Graphics
