How do i get a 32bit system run a 64bit
Last response: in Windows 7
I'm confused on what you are asking here. Do you need a 32-bit program to run on a computer running 64-bit Windows 7?
If you want to move from 64-bit Windows 7 to 32-bit Windows 7, you can only do so by performing a clean installation.
Please clarify,
Cassandra
Microsoft Windows Outreach
Hi newcomer and welcome to the Tom's hardware forum.
1- If u want run a x64 bits application in a 32bit OS that's not possible.
2- If u want run a 32 bits applications in a x64 OS u only need install it and use it.
Ask the community
