Difference between card manufacturers?
Morwing
43
Hello all readers,
I've been thinking of purchasing a new graphics card, most probably a Radeon product. But I'm somewhat baffled by the numerous card manufacturers, and foremost, the price differences between them. How does a Sapphire Radeon 9500 Atlantis Pro 128 MB differ from a Hercules 3D Prophet Radeon 9500 Pro 128 MB? Or does it all? Is the 40 € price difference just because of Hercules is a bigger brand than Sapphire is?
40 € is a nice sum, and if possible, I'd like to save it... So is it a safe bet to go after price, and skip the brand?
- Jan
cleeve
Illustrious
Brand doesn't really matter... all 9500 PROS are clocked the same and will perform the same.
Sapphire even makes Ati's own cards, I believe.
The only difference is if you plan to overclock. Some manufacturers use RAM that overclcoks better. Not sure which ones, tho.
Radeon 9500 w/256 bit memory bus @ 367/310
AMD AthlonXP 2000+
3dMark03: 3439
The Hercules likely comes with built-on Ramsinks and such. The question is whether the differences warrant the extra cost to you. If you DON'T overclock then it likely won't make a diff to you (also if you were a DIY moder).
Here's the THG reviews of the <A HREF="http://www6.tomshardware.com/graphic/20021104/r9700pro-cards-10.html" target="_new">Hercules</A> and <A HREF="http://www6.tomshardware.com/graphic/20021104/r9700pro-cards-13.html" target="_new">Sapphire</A> 9700Pro cards, expect similar differences in the 9500Pro, but you'd have to look for specific reviews to be sure. The THG article just gives you some head-to head background on the brands.
In general the Hercles is slightly better build, but unless you REALLY want a Hercules, and are REALLY serious about overclocking [although if you were you'd likely mod the HSF and Ramsinks yourslelf]) you likely won't notice the difference. Check for reviews using Google, then see if you think the slight bonuses are worth the extra cash (40euros being a fair bit of change).
- You need a licence to buy a gun, but they'll sell anyone a stamp <i>(or internet account)</i> ! <A HREF="http://www.redgreen.com" target="_new"><font color=green>RED</font color=green> <font color=red>GREEN</font color=red></A> GA to SK :evil:
xeenrecoil
842
I really like Hercules products, they have always been great cards, and it totally pissed me off when they stopped making Nvidia cards after the GF3 titanium series, i was so dissapointed -=(
XeeN
