Archived from groups: microsoft.public.windowsxp.help_and_support (
More info?)
I was really reluctant to suggest something so labor intensive, when so many people are reporting various symptoms like yours.
Something in SP2 is obviously at fault, but the problem has so many fixes, it's hard to say which way you should go.
The nice thing about a rebuild, of course, would be that you would Know it is a 'incompatible' driver problem, and be able to look
for something there. On the other hand, 'relic damage' from fixing spyware, or virus would be fixed by a rebuild.
If you run an XP "Upgrade"setup, from the original, or "Gold" version of the setup CD, and you have SP2 installed, it might go into
a setup loop, and you could lose your install. Uninstall SP2, BEFORE you Upgrade setup from CD (that lacks sp2 on it.)
875350 - How to remove Windows XP Service Pack 2 from your computer:
http://support.microsoft.com/default.aspx?kbid=875350
How to Perform a Windows XP Repair Install:
http://michaelstevenstech.com/XPrepairinstall.htm
Mark L. Ferguson (NOT an MS-MVP)
FAQ for MS Antispyware version 1.0.509
http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
marfers notes for windows xp
http://www.geocities.com/marfer_mvp/chatNotes.htm
"Katman" <Katman@discussions.microsoft.com> wrote in message news:4801B13B-7111-4446-A18D-CDA5545172F9@microsoft.com...
> Nope, not this one, followed all steps, everything was as it shoud have
> been.
> Autorun for the CD rom drive does not work though
> Should I just give up and rebuild Windows?
> Thank you for your help so far
> "Mark L. Ferguson" wrote:
>> The AutoRun feature or the AutoPlay feature does not work when you insert a CD-ROM in the drive:
http://support.microsoft.com/default.aspx?scid=kb;en-us;330135
>> "Katman" <Katman@discussions.microsoft.com> wrote in message news:514D7EDD-7955-4B67-BBE5-D3B75AB25F9E@microsoft.com...
>> > Tried it and rebooted, but no change
>> > everything was already set as it should be, but i wnet through the steps
>> > anyway
>> > anymore ideas?
>> >> Locate and click the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Protected Storage System Provider On the
>> >> Edit
>> >> menu, click Permissions . Click the registry key for the user that is currently logged on and ensure that Read and Full
>> >> Control
>> >> are
>> >> both set to Allow . Click the Advanced button, ensure that the user that is currently logged on is selected, that Full Control
>> >> is
>> >> listed in the Permissions column, and that This Key and Subkeys is listed in the Apply to column. Click to select the Replace
>> >> permission entries on all child objects with entries shown here that apply to child objects check box. Click Apply , and then
>> >> click
>> >> Yes when you receive a prompt to continue. Click OK , and then click OK again
>> >> "Katman" <Katman@discussions.microsoft.com> wrote in message news:04AEB36E-4045-42FF-BBF5-09003179EEFC@microsoft.com...
>> >> > Tried that already, made no difference, I dont think the problem is a USB
>> >> > problem as I have a USB scanner and that is working OK (Bear Paw Scanner).
>> >> > The FDD is connected to the FDC and the CD rom is connected to the IDE. I
>> >> > found that if I boot windows with a disc in each drive, they are both
>> >> > accessable until I remove them. When I re-insert, they revert back to
>> >> > unreadable. Problem appears to be with windows and its interface with
>> >> > removable storage devices.
>> >> >> USB Hub Power Management - disable : Start/run, type DEVMGMT.MSC , then rightclick each USB Hub device, Properties, uncheck
>> >> >> the
>> >> >> box
>> >> >> on the Power Management tab.
>> >> >> "Katman" <Katman@discussions.microsoft.com> wrote in message news:4052E0C1-1951-4898-B0EE-3073DFAAB528@microsoft.com...
>> >> >> >I have a problem with my PC
>> >> >> > Upgraded to service pack 2, now none of my removable storage devices are
>> >> >> > working correctly.
>> >> >> > FDD comes up with Please insert disk into drive a:
>> >> >> > CD loads, but displays no files or folders on disk, Disc name remains CD-Rom
>> >> >> > (D
>> >> >> > Tested Digital Camer USB connection and USB Disk both show as removable
>> >> >> > Drive (E
- gives same response as FDD when trying to access either
>> >> >> > Tested USB Scanner - tested OK
>> >> >> > Booted to safe mode and retried devices - all working normally, all access
>> >> >> > is available
>> >> >> > Run msconfig, set for diagnostic startup and rebooted to normal desktop -
>> >> >> > Found devices connected during boot were avaiable (USB Disk and Camera), but
>> >> >> > if removed and reconnected, reverted to previous problem, CD and FDD still
>> >> >> > same
>> >> >> > Tested booting from FDD and CD - Both booted OK
>> >> >> > Would really appreciate any ideas, had this problem before and ended up
>> >> >> > rebuilding entire OS from scratch was only thing that worked.
