hello,
well, my comp is crap yea i know. i know the processor will REALLY degrade performance on any of these vids mentioned. but i figure i can get away playing ut 2003 at lowest settings with one of theses vids:
9500 pro/non pro
9700 non pro
system: crap
p3 650
448 pc133 ram
mobo: qdi billianx9 <--this is the thing
i need to ask u guys if the vid i wanna buy will work with this mobo even at 2x. from what i understand, yea it will, but its better to check with more people aswell
This is a link to my mobo on the qdi website
9500 specs
9700
now, on the site is says this 2x/4x/8x crap, or with some universal 3.0 bus config blah blah. i really dont wanna fry or ruin my card or anythnig so if some1 explained this agp stuff with voltages etc to me ill really appreciate it, cause if it doesnt work i wanna take it back
and lastly, the one im gonna get might be a sapphire. on the ati site it says 2x/4x/8x...the sapph says 8x. does that mean only 8x, or they just didnt put the others in...? does ALL 9500/9700 chipsets that ati makes work with 2x/4x/8x nonetheless?
thanks in advance,
Spydee.
9500 pro/non pro
9700 non pro
system: crap
p3 650
448 pc133 ram
9500 specs
9700
thanks in advance,
Spydee.
