Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I noticed I can double click the startmenu button or right
click->Explore and it will open explorer, and the same works for the
"Program" menu item, but I if I try to "Explore" from anything inside
"Programs" it doesn't open explorer. It jsut closes the Startmenu and
nothing after that.
It's been like this for a while, but I remeber it working in the past.
"SR" <none@none> wrote in message
news:%238bCW11IFHA.3500@TK2MSFTNGP14.phx.gbl...
>I noticed I can double click the startmenu button or right click->Explore
>and it will open explorer, and the same works for the "Program" menu item,
>but I if I try to "Explore" from anything inside "Programs" it doesn't open
>explorer. It jsut closes the Startmenu and nothing after that.
> Is this a known bug? Is it fixable?
> Thanks for any help.
> XP Pro SP2 (All latest updates)
