Hi all, first post here. I just installed a GeForce FX5900 (standard, 128mb). When I booted up into Windows for the first time (XP Home) it finds the card no problem. Next time I boot up the computer, under Device Manager it has the yellow flag with exclamation point for GeForce FX5900. It says that it is not present. I uninstall it, use the add new hardware wizard, and again it finds it no problem. Latest drivers for 5900, and also latest MOBO AGP driver.
I also get BSOD with a MACHINE_CHECK_ERROR 0x09C not every time, but most times when running 3D games. The BSOD doesn't come on initially, and there is no one thing that sets it off. Also, my old GeForce 3 Ti500 which used to run perfectly, now has same symptoms as 5900. Added 2 case fans, however, when I bought the 5900. Wondering if my power supply is stretched to the limit...
My gut feeling is problem with motherboard (ECS K7S5A). I know, K7S5A only has AGP 4X, but it should still find the card upon reboot. Also wondering if power supply is maybe not sufficient (Antec 350W). (2 hard drives, 2 CD's, 4 case fans, also the 5900 has a power cable plug in too.)
CPU: Athlon 2400, does the same with Athlon 1400 too. RAM sticks are brand new.
Any ideas?
Jeff L
Any ideas?
Jeff L
