Power Jack replacement
amac2000
I have just replaced the power Jack does anyone know how to test connections prior to re-installing motherboard into laptop.
I want to check that I have soldered properly and connections are good.
Thanks
Andy
you should be able to bench test it by plugging in the charger and pushing the little button that would be below
the on -off switch
dont do this if you removed the cpu heatsink
if the cpu fan spins then powers going through the power jack and you can re-assemble it
amac2000
Thanks for the replies but it is my 1st attempt at soldering and I want to make sure that the soldered connections are okay prior to powering upas dont want to short out m/board.
I have removed heatsink and processor.
thanks Andy
