G
Guest
Guest
Archived from groups: rec.games.trading-cards.magic.rules (More info?)
This may be a long post. I apologize in advance.
I'm having some trouble with the power and toughness switching effects
-- specifically older vs. newer ways and timestamp order
There are 3 cards involved:
Hero’s Resolve
1W
Enchant Creature
Enchanted creature gets +1/+5.
About Face
R
Instant
Switch target creature’s power and toughness until end of turn.
Effects that alter the creature’s power alter its toughness instead,
and vice versa, this turn.
Strange Inversion
2R
Instant - Arcane
Splice onto Arcane 1R (As you play an Arcane spell, you may reveal
this card from your hand and pay its splice cost. If you do, add this
card’s effects to that spell.)
First, the bit on timestamp and dependency. The rule says:
418.5c An effect is said to "depend on" another if (a) it is applied
in the same layer as the other effect (see rule 418.5a) and (b)
applying the other would change the text or the existence of the first
effect, what it applies to, or what it does to any of the things it
applies to. Otherwise, the effect is considered to be independent of
the other effect.
I can't figure out if there's a dependency here or not. One of the
things above says "what it does to any of the things it applies to".
In a case using About Face and Hero's Resolve, the exact effect of
Hero's Resolve seems to depend on About Face. However, I'm unsure
about the other way around. The effect of About face is to switch the
P/T no matter what,making it seem independent, but the P/T values
would be different, making it seems dependent. Which is it? And if
you're using Strange Inversion instead, where it doesn't flip-flop the
roles of P/T effects, does this change dependency?
OK...now to the end-results themselves. I'll quickly do the 4
situations I'm interested in. Let's just say that they're applied to
a vanilla 1/1 creature.
1. Hero's Resolve is already enchanting the creature. About Face
targets it and resolves. What is the P/T?
2. About Face targets the creature and resolves. Then Hero's Resolve
enchants it. What is the P/T?
3. Hero's Resolve is already enchanting the creature. Strange
Inversion targets it and resolves. What is the P/T?
4. Strange Inversion targets the creature and resolves. Then Hero's
Resolve enchants it. What is the P/T?
In case you're wondering, I'm building a deck around this highly
annoying theme, and I need to know in advance how it works (not that
any of the other players will believe me anyhow).
Thanks for the patience,
Rick Kunkel
Hero’s Resolve
1W
Enchant Creature
About Face
R
Instant
Strange Inversion
2R
Instant - Arcane
the other effect.
Rick Kunkel
