Laptop Restart connect the power adapter
Hello
My Toshiba satellite a300 laptop restart when i connect the power adapter. but it will charge in off mode. I can't work with connect the power adapter. give me a right solution for resolve this problem.
Thank you
5 answers Last reply
More about laptop restart connect power adapter
  1. Something has gone wrong with the rectifier in the laptop.
    You need to take it to a service center and get it looked at.
  2. What about taking out the battery? It won't help to solve the problem, but it would be interesting to know if it works that way.
    Thank you for help
    if I take out better after connect the power adapter and switch on it will on but 2 or 3 minutes it will restart
  4. mr_j4s said:
    Thank you for help
    Ahh, too bad. It means, it's not the battery's fault. And it can't be the charger either, I guess, because it works when the computer is off... I'm afraid, you'll need to see the doctor with it, just as alyoshka suggested.
    You don't have a friend around with an exactly same type of charger, do you? (Hope dies last.)
  5. This is a known problem in some Toshiba Satellite laptops due to a faulty NEC/TOKIN Proadlizer, which requires replacement. This shows a way to repair it: http://gs138.photobucket.com/groups/q251/S1BXDWUERU/
Laptops Connection Power Adapter
