bad direct sound driver
Forum Windows XP : Windows XP General Discussion - bad direct sound driver
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
"Direct sounds output V2.2.10 error" Bad direct sound driver. Please install
proper drivers, or select another devie in configuration" comes up when i try
and play any music. I think I need to reload my sound drivers but it shows
that they're still there, so i dont know what to do.
Sponsored Links
Open system properties,device mgr,sounds,expand the tree,locate the
sound card or on-board text,R.click,select,uninstall (actually uninstalling
all
is ok too)then close out,shutdown computer.On restart,xp will reload all,you
might also open windows update before another restart,update will install
drivers if needed.
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > bad direct sound driver
There are 553 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
