Does the compaq nx6325 have internal power problems?
does the hp/compaq nx6325 have power problems internally.if so,how do I fix it?
2 answers Last reply
More about does compaq nx6325 internal power problems
  1. Hi :)
    I own a lappy repair company....
    And no not usually...
    What is the problem exactly ?
    All the best Brett :)
  2. Brett928S2 said:
    Hi :)
    well i had to replace the battery due to it would not take a charge.then my a/c adapter when bad so i got one of those.now my laptop will not power up. i checked for voltage on both and they both have.i figured something inside is loose. thanks for your reply...Rick
Hewlett Packard Compaq Power Laptops
