CD player problem, HELP!
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Doesn't anybody have any suggestions?
My CD player/burner has stopped working.
When I put a CD in the mouse pointer changes to a CD for a few seconds than
back to the regular pointer.
When I go and view the contents on the CD in Explorer there is nothing there
(no files). I have tied many different CD's (data, music & games) all with
the same results.
I have uninstalled and reinstalled the drivers for the CD player, no help.
I purchased a new CD player/burner and have the same results.
I think all my problems started back when I updated Media Player.
Any suggestions or help would be appreciated.
P.
8 answers Last reply
More about player problem help
  1. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Just a thought.... have you enabled Auto Start on the drive? What are the
    other settings when you click hardware? Best of luck to you
    Ron J
    > the same results.
    > P.
  2. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    I think auto start was enabled, but I can't find the settings. Where would I
    check?
    Under the Hardware tab (properties) there are four other tabs: General,
    Properties, Volumes and Details.
    In the General tab, it states that the drive is enabled and working
    properly.
    Where else could I look?
    Thanks for the reply.
    Pete
    "Ron J" <RonJ@discussions.microsoft.com> wrote in message
    news:49B29C18-4561-47E4-906F-BA5C9349367B@microsoft.com...
    > the
    > Ron J
    >> than
    >> there
    >> with
    >> the same results.
    >> help.
    >> P.
  3. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Hey Pete,
    Sorry it took so long to post back. I just got in.
    Ok, To check if Auto Start is on =Start>My computer>
    Choose CD drive>click on Auto Play, 2nd choice on right in XP Pro> Click on
    the drop down folder and make your choice> Under Actions click Select Action
    To perform> you will see a choice depending on your fav. player etc, I use
    windows 10 works well and no troubles with it. > If you plan on using the CD
    drive the same way much of the time, I would leave the Prompt me each time
    option off, it can get to be a real pain> The hardware tab has a trouble
    shoot option that I find pretty good and you can also check your drivers> If
    you want this drive to record> click on Recordings> click enable CD recording
    on this drive> click the drop down window arrow> chose a drive for windows to
    store an image of the CD to> click the second drop down arrow> chose the
    best speed for your drive > tip: fastest is not always bestest > I prefer to
    click on the Auto eject afer writing, that is up to you> click apply> click
    Ok > cross fingers and put a CD in drive.! If it does not start> double
    click on Auto Start> sometimes I have to jump start my drive but after that
    it runs well for some time. I hope this was the info you were looking for
    Pete. Best of luck to you.
    Ron J
    > check?
    > properly.
    > Pete
    > > the
    > > Ron J
    > >> than
    > >> there
    > >> with
    > >> the same results.
    > >> help.
    > >> P.
  4. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Ron,
    Thanks for all the advice.
    I tried everything you suggested and still the system will not recognize
    anything in the CD player.
    I even rebooted a couple of times after making changes.
    I think I'm going to have to clear the hard drive and reload XP Home.
    It was my last resort, but I guess that's what I will need to do.
    Thanks again for your help,
    Pete
    news:EDD324C5-68F1-4ACD-B2C9-B3A6EC4DFA03@microsoft.com...
    > Hey Pete,
    > on
    > Action
    > use
    > CD
    > If
    > recording
    > to
    > to
    > click
    > that
    > for
    > Ron J
    >> would I
    >> check?
    >> properly.
    >> Pete
    >> > are
    >> > the
    >> > Ron J
    >> >> than
    >> >> there
    >> >> with
    >> >> the same results.
    >> >> help.
    >> >> P.
  5. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Don't be so drastic.
    First, remove the player from the system first via Device manager, buy or
    borrow a couple of replacement leads, the let XP find the drive again.
    johnf
    > Ron,
    > Pete
    >> Hey Pete,
    >> Click on
    >> Action
    >> use
    >> the CD
    >> time option off, it can get to be a real pain> The hardware tab has a
    >> trouble shoot option that I find pretty good and you can also check
    >> your drivers> If
    >> recording
    >> windows to
    >> the best speed for your drive > tip: fastest is not always bestest > I
    >> prefer to
    >> click
    >> double click on Auto Start> sometimes I have to jump start my drive
    >> but after that
    >> looking for
    >> Ron J
    >>> would I
    >>> check?
    >>> General, Properties, Volumes and Details.
    >>> properly.
    >>> Pete
    >>> > are
    >>> > the
    >>> > Ron J
    >>> >> seconds than
    >>> >> nothing there
    >>> >> all with
    >>> >> the same results.
    >>> >> no help.
    >>> >> P.
  6. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    I will give this a try John but first I will need a little more info. (I'm
    not too technically orientated),
    I can uninstall the player with device manager (no problem),
    can you explain a little further about the replacement leads?
    Thanks,
    Pete
    "johnf" <john_f@bigpond.net.a> wrote in message
    news:%23ZyksI$JFHA.2132@TK2MSFTNGP14.phx.gbl...
    > johnf
    >> Ron,
    >> Pete
    >>> Hey Pete,
    >>> Click on
    >>> Action
    >>> use
    >>> the CD
    >>> your drivers> If
    >>> recording
    >>> windows to
    >>> prefer to
    >>> click
    >>> but after that
    >>> looking for
    >>> Ron J
    >>>> would I
    >>>> check?
    >>>> properly.
    >>>> Pete
    >>>> > are
    >>>> > the
    >>>> > Ron J
    >>>> >> seconds than
    >>>> >> nothing there
    >>>> >> all with
    >>>> >> the same results.
    >>>> >> no help.
    >>>> >> P.
  7. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Well, replace the 40 or 80 lead you're currently using - (it's easy to see
    the difference between a 40 & an 80 = same width but more wiires) but FIRST
    make sure the original is fully plugged in B4 you do that (test to see if
    that rectifies the problem - (reboot)
    If that doesn't help, borrrow & replace all flat cables to the drive -
    possibly a faulty cable which I doubt, it's callled a 'sequentuel process
    of elimination'
    Next step if that fails is to borrow any oll CD drive, try that & let's know
    what happens then
    johnf
    > (I'm not too technically orientated),
    > Thanks,
    > Pete
    >> or borrow a couple of replacement leads, the let XP find the drive
    >> again.
    >> johnf
    >>> Ron,
    >>> recognize anything in the CD player.
    >>> Pete
    >>>> Hey Pete,
    >>>> Click on
    >>>> Action
    >>>> etc, I use
    >>>> the CD
    >>>> your drivers> If
    >>>> recording
    >>>> windows to
    >>>> chose the best speed for your drive > tip: fastest is not always
    >>>> apply> click
    >>>> but after that
    >>>> looking for
    >>>> Ron J
    >>>>> would I
    >>>>> check?
    >>>>> properly.
    >>>>> Pete
    >>>>> > are
    >>>>> > the
    >>>>> > Ron J
    >>>>> >> seconds than
    >>>>> >> nothing there
    >>>>> >> all with
    >>>>> >> the same results.
    >>>>> >> no help.
    >>>>> >> P.
  8. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Thank you.
    I will give this a try and report the results.
    Pete
    news:eHKbkoEKFHA.1340@TK2MSFTNGP10.phx.gbl...
    > FIRST make sure the original is fully plugged in B4 you do that (test to
    > see if that rectifies the problem - (reboot)
    > of elimination'
    > know what happens then
    > johnf
    >> Thanks,
    >> Pete
    >>> again.
    >>> johnf
    >>>> Ron,
    >>>> Pete
    >>>>> Hey Pete,
    >>>>> Click on
    >>>>> Action
    >>>>> etc, I use
    >>>>> the CD
    >>>>> your drivers> If
    >>>>> recording
    >>>>> windows to
    >>>>> apply> click
    >>>>> but after that
    >>>>> looking for
    >>>>> Ron J
    >>>>>> would I
    >>>>>> check?
    >>>>>> properly.
    >>>>>> Pete
    >>>>>> > are
    >>>>>> > the
    >>>>>> > Ron J
    >>>>>> >> seconds than
    >>>>>> >> nothing there
    >>>>>> >> all with
    >>>>>> >> the same results.
    >>>>>> >> no help.
    >>>>>> >> P.
Pointer Burner CD-Rom Windows XP
