Archived from groups: microsoft.public.windowsxp.help_and_support (
More info?)
First thing to check is the 'sessions'. Have her go to start/run, and type FSMGMT.MSC. The Sessions folder shows all connections (if
found, the menu does a "disconnect all sessions")
The password protection should be enough to stop other users, and permit you to connect.
The RA failure is probably due to the use of a NAT somewhere in the connection. (A router, hub, etc.) An email invite can be
slightly hacked to allow the connect, if so.
Mark L. Ferguson (NOT an MS-MVP)
FAQ for MS Antispyware version 1.0.509
http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
marfers notes for windows xp
http://www.geocities.com/marfer_mvp/chatNotes.htm
"Chris Cowles" <NoSpam@For.me> wrote in message news:u3kE3J4JFHA.3928@TK2MSFTNGP09.phx.gbl...
>I use Remote Assistance to help resolve problems on my Mom's computer. We both have XP Pro SP2, fully patched. Fast user switching
>is enabled on her computer. Her primary account is limited.
> Sometimes, when she turns off the computer, she gets a pop-up that says another user is connected. I know that message appears if
> you fast-switch from another account, but she sees it even if she turned on the computer from a cold start and never logged into
> the administrator account.
> This makes me suspicious about someone having logged in with remote desktop. She's on a DSL line and had some viruses and malware
> at one point. I did not do a full rebuild but spybot and norton didn't find anything after the initial discovery was cleaned up.
> I assume anyone logging into RD would have to have a password, would they not? Or can guest somehow log in? To address the
> possibility of someone having the admin password, we just changed it. I can't disable terminal services because remote assistance
> would then be disabled, as well.
> I have a static IP address on my computer. I can configure windows firewall to use certain programs only from a specified ip
> addresses. If I can do that with the programs that run terminal services, I could be confident nobody but me can connect. Can I do
> that? If so, how?
> It may or may not be related but, every time we attempt to use RA and I connect, she gets a pop-up that says remote assistance
> failed. Then everything proceeds normally. She has to dismiss the message box but after doing so everything works fine.
> All sincere suggestions are appreciate.
> Thanks in advance.
