Flash BIOS / battery problem
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hi all.
I have an old Latitude HS 400ST. It doesn't have a CD drive nor A drive.
My battery suddenly stopped working (was holding several hours charge
before this) a week ago and the research I have done suggests upgrading
the BIOS to A09 (which I believe has a battery re-calibration tool)
might solve the problem. However, I have now discovered what should have
been obvious - I can't boot to DOS and therefore can't flash the BIOS.
I have acquired a USB A and CD drive and both of these are not bootable.
The BIOS upgrade won't run from Windows. I would appreciate help on how
to overcome this problem.
Thanks
Paul
G
Guest
Guest
St Paul wrote:
> Hi all.
> upgrading the BIOS to A09 (which I believe has a battery
> re-calibration tool) might solve the problem. However, I have now
> discovered what should have been obvious - I can't boot to DOS and
> therefore can't flash the BIOS. I have acquired a USB A and CD drive
> and both of these are not bootable. The BIOS upgrade won't run from
> Windows. I would appreciate help on how to overcome this problem.
> Thanks
> Paul
I couldn't find your particular model on Dell's site (but you obviously
did). Dell generally provides several different files for BIOS upgrade
-- one of which does not require a floppy or bootable device other than
the hard disk. Are you certain there is not a BIOS upgrade for that
model which doesn't require another device?
G
Guest
Guest
Jerry Park wrote:
> St Paul wrote:
>> Hi all.
>> Thanks
>> Paul
I will go and look again and report back here.
Thnx.
Paul
