Archived from groups: alt.sys.pc-clone.dell (More info?)
In most cases, they're easy to replace, if not to get at.
See support.dell.com. Enter your service tag, choose Documentation,
Service Manual.
nospam wrote:
> Is it possible to replace the CMOS Battery in an Inspiron or do I have
> to return the unit to Dell?
> If it's possible where does the battery live, how do I get at it?
> Thanks
Thanks for the info.
I have found the files but all it says is replace the battery, contact
Dell.
It will cost more to return the unit than it is worth.
Guess I will have to take a screwdriver to it!
In message <34e0egF4a9v1aU1@individual.net>, Edward J. Neth
<ejn63@netscape.net> writes
>Service Manual.
>>have to return the unit to Dell?
>> Thanks
