Sleep resume problem
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
well
Its set a s3/str but still not working the only other option is s1 -
any more ideas before i chuck it out the window in temper?
Mark L. Ferguson Wrote:
> Maybe you reset the BIOS settings to 'default' and the 'S3' settings for
> things involved in 'standby' were not set right. Open BIOS
> setup, and be sure you are set to 'S3', rather than 'S1'.
> bios setup access keys. Go to:
> http://michaelstevenstech.com/bios_manufacturer.htm
> Mark L. Ferguson (NOT an MS-MVP)
> FAQ for MS Antispyware version 1.0.509
> http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
> marfers notes for windows xp
> http://www.geocities.com/marfer_mvp/chatNotes.htm
> "Bondgirl2003" Bondgirl2003.1lyl1o@pcbanter.net wrote in message
> news:Bondgirl2003.1lyl1o@pcbanter.net...-
> HI Thanks mark
> The hardware is exactly the same as original as is the Bios as all
> that
> was changed was a reinstall of the os. Does this mean it could be as
> simple as a bios update? If so how to I find such an update?
> Mark L. Ferguson Wrote:-
> Your hardware and BIOS can't handle the XP "ACPI" and 'standby'
> feature
> correctly. You would need new hardware, or a better BIOS to
> do it.
> "Bondgirl2003" Bondgirl2003.1lw9pn@pcbanter.net wrote in message
> news:Bondgirl2003.1lw9pn@pcbanter.net...-
> Hi guys,
> My Packard bell I extreme died. It has now been reinstalled with
> Windows xp and everything is working fine except the sleep function.
> I can press the Sleep button on the keyboard and it will sucessfully
> standby. However it won't resume. I have tried all the buttons on the
> keyboard and moving the mouse. If i press the power button the light
> goes green but there still isnt any power to the monitor, mouse or
> keyboard.
> Its still using the original keyboard so I know it can do it.
> I also brought a new keyboard and installed the drivers but yet again
> that still didnt work.
> I have already checked the deivce properties and there is no "allow
> this device to wake up pc" option
> Help before I go mad with it?
> Bondgirl2003--
> Bondgirl2003-
Bondgirl2003
1 answer Last reply
More about sleep resume problem
  1. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    You can run a setup of XP that disables ACPI (standby features) completely.
    Run setup again, and press F-7 at the 'Press F-6 for RAID' prompt. This will disable ACPI and enable APM
    http://support.microsoft.com/support/kb/articles/Q216/2/51.ASP
    marfers notes for windows xp http://www.geocities.com/marfer_mvp/chatNotes.htm
    "Bondgirl2003" <Bondgirl2003.1m0fpn@pcbanter.net> wrote in message news:Bondgirl2003.1m0fpn@pcbanter.net...
    > well
    >> HI Thanks mark
    >> that
    >> feature
    >> do it.
    >> Hi guys,
    >> keyboard.
    >> Bondgirl2003--
    >> Bondgirl2003-
    > Bondgirl2003
BIOS Windows XP
