Considering this refurbished laptop please help
Last response: in Laptop Tech Support
March 21, 2012 12:11:42 AM
no pictures, no reviews, and refurbished. is this a good idea?
it also boasts a AMD Radeon HD 6755G2 Dual GPU
what exactly does that dual gpu mean. Is this cross fired? and how would I access crossfire if so?
thanks
More about : refurbished laptop
a c 249 D Laptop
March 21, 2012 12:33:11 AM
Hi :)
No its not crossfired :)
And thats a LOT of money for a refurb (that MAY have had major problems) unless its got a CAST IRON guarantee...
I wouldnt....and I sell lappies in my shops...
All the best Brett :)
m
l
March 21, 2012 12:40:16 AM
Brett928S2 said:
Hi :)
thanks, If you sell anywhere near New England I'm come in your shop.
also thinking about this one http://www.newegg.com/Product/Product.aspx?Item=N82E168...
m
l
a c 249 D Laptop
March 21, 2012 12:48:03 AM
Hi :)
Well I am actually In England (the country lol) so a little far for you to travel :)
The second one looks better but as I really am not totally familar with the American market, I would wait for some others to comment..
m
l
March 21, 2012 1:04:17 AM
Not bad deals either one, but I cant find what warranty they are saying they come with, if you are concerned, then the 2 year warranty addon might be worth it. Either one looks fine, personally the second one is more to the liking, but this is a personal preference only. I dont think either one is a bad deal. I havent bought a refurb HP from newegg, but have bought over 15 laptop refurbs from them in the past and have not had one issue (mostly Asus). Refurbs are a good way to get a good deal if you can verify what terms are the warranty in case something goes wrong. At the worst, I believe most of them are 90 days like the Asus I bought were. But you can always extend that coverage at the time of purchase, and in the case of Asus, even buy it afterwards.
m
l
a b D Laptop
March 21, 2012 1:04:54 PM
It IS asymmetrically crossfired with the A8-3500M's built-in Mobility Radeon HD 6620G but that only really works properly in DX11 gaming. Honestly though, I've never had a refurbished laptop that didn't cause me problems and that price isn't all that impressive when you consider that you could get a new one with almost the exact same specs for $20 less and a full warranty instead of the 90-day BS that comes with refurbished products:
http://www.tigerdirect.ca/applications/SearchTools/item...
m
l
March 21, 2012 1:24:33 PM
The second laptop, the Acer would be more to my liking.
m
l
