Tom's Hardware > Forum > Games General > Console Gaming > Vectrex Screen Problem
Forum Games General : Console Gaming - Vectrex Screen Problem
Archived from groups: rec.games.vectrex (More info?)
Hello All,
A little/big problem with a vectrex I have. Screen is intermittently
working and I am not sure the reason why. On several occasions I have
turned the machine it has worked fine, when I turn back off and plug
cartridge in the screen does not work - sound present but no display. Take
cart out and turn on to see if Minestorm works - but no go also. I have
turned the brightness up and notice that there is a very small white line
part way across the middle of the screen left to right. There is 'movement'
visibly in the line, that is I can see the line flicker when I am shooting
in minestorm.
Any ideas, or can someone point me in the right direction?
Cheers,
CM.
Sponsored Links
If it's intermittent like that, I'd say there's could be a bad contact or
it's a heat related fault (does it happen when the Vec has been switched on
a while ?)
Try re-seating the chips, if that doesn't work use component cooler to
pinpoint the bad one.
Richard H.
Reply to Anonymous
Thanks for the response Richard. I thought it may have been a heat problem
but it has been occuring as soon as the machine is turned on. I will
recheck the chips though and see what happens.
"Richard Hutchinson" <richard.hutchinson@dsl.pipex.com> wrote in message
news:40f00643$0$6450$cc9e4d1f@news-text.dial.pipex.com...
on
> a while ?)
> Richard H.
Reply to Anonymous
There are 653 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
