Tom's Hardware > Forum > Games General > Games General Discussions > neverwinter nights problem
Forum Games General : Games General Discussions - neverwinter nights problem
hey guys, i just posted this over at bioware.com to get some help but i thought i would post here to cause i always seem to get my problems solved here too. the problem is that the game will freeze and sound will repeat i tried everything here in both version 1.10 and now 1.23. I disabled fastwrites, when from 4x to 2x AGP, lowered my graphics down some, Im using windows xp right now and before i installed winxp i did a format and using standard pc cuz i was have stability problems with ACPI sharing irqs so my sound card and graphics card are on different irqs, I did this registry edit that microsoft had at there site for AGP to hang in some programs/games. Im running an amd thunderbird socket A 700mhz, soundblaster x-game with 5.1.2603 drivers, i have tried previously drivers like 5.1.2602 and also the ones at creative.com, i have a geforce 4200 gainward 64MB using the 30.82 drivers and i have the latest via 4in142 drivers i think it was and i still get the same problem and also i have an antec 400 watt power supply and other games like jedi knight 2 run great and dungeon siege. Any suggestions would be appreciate since i havent been able to play this game longer than 5 minutes since i got it early august. Thanks
Sponsored Links
I don't know if you have but you might want to try disabling EAX in game under the sound options.
I've seen a few games where having EAX on will cause some major stability issues.
Hope that helps :)
Reply to Tomlin
do u have an illegal copy of winxp or nwn?
does it freeze and makes you reboot or can u do a 3 finger salute combo to get back to winxp again?
did you overclock anything? if you did, set everything to its normal clock.
try the new detonator 4 drivers...
check for overheating problems...
you dont have to disable anything or lower anything, it should run fine with ur setup...set everything to its default.
My computer is so fast it proves the theory of relativity wrong... :eek: <P ID="edit"><FONT SIZE=-1><EM>Edited by grassapa on 09/02/02 01:12 PM.</EM></FONT></P>
Reply to grassapa
There are 759 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
