Problems loading CD-ROMS
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I've been trying to load SimCity 3000 and Action Replay CDs on my XP but with
both of them I get a error that reads
C:\WINDOWS\SYSTEM32\CONFIG.NT. The system file is not suitable for running
MS-DOS and Microsoft Windows applications. Choose 'close' to terminate the
application.
While SimCity is older, the Action Replay disk is not. Any advice? Thanks!
1 answer Last reply
More about problems loading roms
  1. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Seems to be an epidemic lately....
    This can be caused by a trojan.
    Get rid of the trojan.
    Update your antivirus software and run a full system scan.
    Copy the autoexec.nt file from C:\Windows\Repair to C:\Windows\System32.
    And set Attributes for autoexec.nt to Read-only.
    Read-only
    [[Specifies whether this file is read-only, which means that it cannot be
    changed or accidentally deleted.]]
    1. Right click the file.
    2. Properties.
    3. Select: ? Read-only.
    4. Click: Apply.
    5. Click: OK.
    16-bit MS-DOS Subsystem error while installing or running a DOS application
    http://windowsxp.mvps.org/16bit.htm
    MS-DOS or 16-bit Windows-based program Error Message
    http://www.kellys-korner-xp.com/xp_m.htm#16bit
    Error message when you install or start an MS-DOS or 16-bit Windows-based
    program
    http://support.microsoft.com/default.aspx?scid=kb;en-us;324767
    Hope this helps. Let us know.
    Wes
    MS-MVP Windows Shell/User
    In news:B8E54AE5-3733-4FCA-9118-47BBF2DE5890@microsoft.com,
    SouthernIndiana <SouthernIndiana@discussions.microsoft.com> hunted and
    pecked:
    > but with both of them I get a error that reads
    > running MS-DOS and Microsoft Windows applications. Choose 'close' to
    > terminate the application.
    > Thanks!
Microsoft CD-Rom Windows XP
