News
Channel Vendors Demand Card Makers Recall Faulty Nvidia Products
Published on July 25, 2008
Taipei (Taiwan) - Due to Nvidia did not clearly explaining the details of the faults reported in its notebook GPUs, some channel vendors have demanded graphics card makers issue a recall for desktop-based discrete graphics cards using the same GPU core, according to sources at graphics card makers. Read more
Sources: Some graphics card makers have insufficient supply of GPUs
Published on October 04, 2004
Supplies of higher-end graphics chips are currently running short of demand by about 20 percent, which may affect some graphics card makers' efforts to boost their October sales, according to sources at Taiwan graphics card makers. Read more
ECS to resume graphics card business
Published on December 28, 2005
Motherboard maker Elitegroup Computer Systems (ECS), which terminated its graphics card production in 2004, is looking to resume the business in 2006, the Chinese-language Apple Daily cited company sources as saying. Read more
Graphics card makers expect Vista to improve profits
Published on September 23, 2005
Windows Vista, Microsoft's next generation OS, is expected to help graphics card makers see increased profits from rising high-end card demand, according to graphics card makers in Taiwan. Read more
Latest Reviews & Articles
Tom’s Winter 2008 Hard Drive Guide
Published on November 24, 2008
Flash-based drives take the performance segment by storm, but the good old hard drive still provides the best bang for the buck as capacities reach 1.5 terabytes. We scanned all the available offerings and found the best drives for winter 2008. Read more
Efficiency: Core 2 Nukes Atom On The Desktop
Published on November 21, 2008
Atom is geared for low-cost, low-power netbooks and nettops, while the device is a poor choice for desktop PC applications. We show you why Core 2 is better, and give some guidance on how to pick the best power supply for your low-power application. Read more
Radeon HD 4870 X2: Four Cards Compared
Published on November 19, 2008
Not only do we have four super-fast Radeon HD 4870 X2s to test, but also a list of 31 other graphics configurations including CrossFire and SLI setups. If you're in the market for AMD's fastest card available, you'll want to see this. Read more
Synology's DS408 Reviewed: Fast NAS For Pros
Published on November 18, 2008
Does a NAS device with high data transfer rate and a Web interface that is easy to configure actually exist? Synology shows how it should be done. But the enclosure is not without its faults, either. Read more
  Tom's Hardware Forums » Graphic & Displays » Graphics Cards » Graphics card or MoBo problem?
Word :   Username :
Bottom
Author
 Thread : Graphics card or MoBo problem?
Profile: stranger
More Information
I am upgrading my computer in preparation for HalfLife 2.
The problem is that when I installed my ATI 9800 PRO card the graphics were corrupted. Various boxes and rectangles with different colors in them as well as all kinds of other crap. I returned the card for a new one and the replacement worked well at first but then the same thing happened. While troubleshooting I found that by wiggling the card a little it seems to make the problem worse but every once in a while I can get it to work fine. I reinstalled my old NVidia gforce 4 card and it works fine and I cannot get the problem to duplicate. Is this a Graphics card issue or a MoBo issue. I also installed a new Antec 430 watt PS. My current system specs are:
Asus A7N8X Deluxe
ATI Radon 9800 Pro
AMD 2800+ CPU
512 Mb Corsair 2700 ram
Please help.
Thanks Dennis
Related Product
Profile: Forum Gigolo
More Information
I've said it before and I'll say it again:
The best way to diagnose computer components is to swap them with working systems.
Find a friend and install your card on their system. Loop 3dMark 03 and see if the Problem occurs. If it does, bad card... or perhaps your motherboard kills Radeons, which is bad.
If it works fine you can safely say that the Radeon is simply not compatible with that motherboard, or there is something screwy with that motherboard.
Radeon 9500 (modded to PRO w/8 pixel pipelines)
AMD AthlonXP 2000+
3dMark03: 3529
TKS
Profile: old hand
More Information
Usually when going from an Nvidia based card...the drivers hang around. Go to driverheaven.net and download the <A HREF="http://www.driverheaven.net/cleaner/" target="_new">driver cleaner</A>. Follow the directions on the page to fully remove the drivers from your system. Reboot...allow windows to install their retarded driver...then install the <A HREF="http://www2.ati.com/drivers/wxp-w2k-catalyst-7-93-030812a1-010735c-efg.exe" target="_new">Catalyst 3.7's</A> and you're set. Things will run smoothly after that. Don't blame the RADEON, blame the Detonators. They 'blow up' any other video card you plug in if it isn't Nvidia. Damn saboteurs anyways. :P
<b><i>Nvidia,</i> the way it's meant to be benchmarked.</b>
Google Ads
