hi i bought a shiny new gfx card without realising it may not work with win 98. When i installed the drivers it said ati win 98 drivers and to some extent it worked, it was not stable though as it was jerky and kept crashing completely, including turning my pc off. I've tried installing some new drivers but now it won't load them after restart and now the pc warns me that it doesn't like my display settings. Has anyone used win 98 with this card?? Should i uninstall it?
Now on starting windows i know get the display box come up with the following error - adapter type incorrect which brings up the colour display settings screen but it only asks me to restart if i ok it. I end up with the same thing on rebooting. If i cancel it continues to desktop.
I realised i had not downloaded the new control panel so i've tried that, along with clearing my drivers with driver cleaner and then reloading dx 9. When i try to install the downloaded drivers i get the zero display instances error. getting nowhere at the moment.
Appreciate any help, thanks
