Archived from groups: rec.games.vectrex (
More info?)
raycremers@hotmail.com (ray) wrote in
news:c9a9ad9c.0502040432.542b70e8@posting.google.com:
> dgo <bakkerpReMoVe@xs4all.nl> wrote in message
> news:<Xns95EE845E413DF696969@194.109.133.29>...
>> mos6507@yahoo.com wrote in news:1106978024.849415.113300
>> @c13g2000cwb.googlegroups.com:
>> > Are there any tricks to getting the Vecflash to work on a modern XP
>> > box?
>> > I have two serial ports on my motherboard but I've only been able
>> > to get the loader to think it's connected twice, and when I told it
>> > to erase, it just sat there forever and I had to close the program.
>> Hi,
>> I've had a similar problem.
>> In my case there was a problem @ the cart's default baud rate. At the
>> default speed for some reason it didn't communicate (it did register
>> a connect sometimes, but when you uploaded an image, it just locked
>> up. There should be a progress bar running).
>> I suggest you contact Richard about this.
>> Regards,
>> dgo
> Mine doesn't work too. At what baud rate did you set it??
> Ray
All I know is that it's an incompatibility problem which occurred on few
systems with an older version of the driver.
Richard swiftly & adequately solved the problem (thanks again Richard!)
and yes like he said, it works flawless ever since! (at least now I don't
have to use my own game bin's and don't have to turn off the Vectrex
everytime I want to load a different game like the with the older Sean
Kelly Multicarts
