Archived from groups: rec.games.vectrex (
More info?)
On Tue, 15 Mar 2005 17:51:24 -0600, Cecil Casey <crcasey934@yahoo.com>
wrote:
>On 3 Mar 2005 13:49:17 -0800, "MadCow" <madcow@gmail.com> wrote:
>>I have a Vectrex that works perfectly except there is no sound. There
>>is not even the common buzzz or static when adjusting the volume. No
>>sound at all.
>>I peeked to see if the wiring fell off the speaker but it looks OK.
>>What else can I look for?
>Two things, first the service diagram shows that on at least some (if
>not all) vectrex systems that the speaker is connected to the main
>board with a pin header. Please double check the J103 connector to
>see it is on well.
I make one mistake here.... IC103 is sitting on the power board
according to the diagrams. So look for these parts on the power
board.
>The second idea is a bit more complex. In the repair manual IC103 is
>listed as a National LM386. This is a low power audio amp. If you
>have a scope, or an old set of headphones and I bit of skill you
>should be able to see the un-amplified signal at R104 on the
> !!!main board!!! <<<Mistake!!! This is on the power board.
> You can step foreword from there to make sure you still have a
>signal at pin 3 of IC103. If you have a good signal there and +9v on
>pin 6 then odds are you need to dig up $0.75 from some where and go
>replace this IC. If this chip is not socketed on your Vectrex I would
>recommend spending the extra money to add a socket as well.
>Hope this helps both of you.
>-Cecil
-Cecil
