Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problem with holding key down..........see inside
Forum Windows XP : Windows XP General Discussion - Problem with holding key down..........see inside
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
When you normally hold a key down, it will type the same letter
[number] across the whole page. Mine won't.. it types it once, then I
have to let up on the key, wait a second or so and press again, etc.
If I am typing along using different letters, it goes right along, but
with a word like "room", then the two o's get hung up, in my having to
wait inbetween. It's the same way with the backspace key.. one at a
time, with a second in between... any thoughts?? TIA
Sponsored Links
Check the typematic rate.
There is a settings in BIOS on some machines and a further setting in Xp.
START> CONTROL PANEL> KEYBOARD>
On the Speed tab, change the Character Repeat section:
Repeat Delay - longer or shorter.
Reply to bar
BAR has mentioned the relative BIOS setting. There are also some settings
in Windows to check:
Control Panel> Keyboard: adjust repeat (default is fast) and repeat delay
(default is towards the short end of slider) speeds. Your keyboard software
may have added additional settings here regarding repeat characters.
Control Panel> Accessibility Options: If Filter Keys is enabled
(blocks/ignores repeated keystrokes), disable it.
Sharon F
MS-MVP ~ Windows Shell/User
In memory of our dear friend, MVP Alex Nichol
Reply to Anonymous
There are 740 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
