Archived from groups: rec.games.video.arcade,rec.games.video.arcade.marketplace,rec.games.video.arcade.collecting (More info?)
I am in the process of making a jamma adapter for a super pac board. I
do not have the coin/credit board. I seem to have everything working,
even the play/test switch. It seems that the pcb is stuck in a
coctkail mode. I activated the play/test switch which confirms table
mode. My question is, how is that changed to upright? Are the boards
cabinet specific or does something need to be grounded? I didnt see
anything on the pinout for it. I have 2 boards and both show CT mode.
There is nothing in the dip settings either. Any ideas? Please post
here or email directly..
Any help GREATLY appreciated!
J2 - pin#15 is your CT pin. Run 2 jumpers. One from a ground & one from J2
#15. Twist the ends of the 2 together & secure with a small
marette(electrical cap). When used with an upright, just seperate the 2
wires & cover the ends with electrical tape.
Hope this helps
T.O. Mike
<takeman@comcast.net> wrote in message
news:1109133088.652832.271170@l41g2000cwc.googlegroups.com...
> TIA
> Troy
Yeesh. Or do it classy and get some insulated QD connectors or even a 2 pin
molex using only one pin. For extra points, perhaps there is a nonused DIP
switch on board?
"Toronto Mike" <mikedewe@sympatico.ca> wrote in message
news:F86Td.15081$uO.515391@news20.bellglobal.com...
> Hope this helps
> T.O. Mike
>> TIA
>> Troy
