Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I just replaced my PC Case and when I finally got it all hooked up my sound
is not working. I do not have a sound card installed, it is integrated on
the motherboard. I did not change any settings, they just stopped working.
When I adjust the volume I hear my internal speaker beeping, but not my
speakers. I checked all of the settings in control panel and device manager,
they all look legitimate. I saw an earlier post with checking the BIOS
settings. I don't know how to do that, so if you answer is check those
settings can you please run through how to do just that? Please help, having
no music on my machine is absolute hell.
Sponsored Links
Hello,
Have you updated your audio drivers?
Reply to Anonymous
There have been a number of posts about this same issue, none of which seem
to have an answer. The remarks that you get about installing newer drivers is
not going to help; I have been trying to upload newer drivers for 6 months
(on and off). I installed a new mother board, sound on the mother board, it
doesn't make more than a small chirp on errors.
I installed PCI audio cards, turned off the MB audio, and still no sound.
The message I get that is relevant is "No Audio Device Installed". Since
there is an audio device, I believe something in Windows XP got screwed up,
when there was an enormous change in the system it was installed on.
Any ideas how to change the installation without going to a re-install?>
Reply to Anonymous
bAT,
Reply to Anonymous
Bat,
If you cannot download your drivers correctly it does not mean no one
else can.
You blame everyone here when you should be after the maker of your
hardware.
Not blame the people trying to help you. Also, if you don't how
to put it back toghter, and , that includes knowing how , as well as, when
to download drivers then don't take it apart . XP is not your problem the
chirps most likely mean the drive is not installed correctly.
Ron J
Reply to Anonymous
Let's back up a step.
I have audio hardware on a motherboard. I have drivers for the audio
hardware. I have installed the driver software for the audio hardware. Device
Manager indicates that the software is installed and selected.
But, from the Control Panel, Sounds and Audio Devices, on the tab Volume,
is the message, "No audio Device Installed". I just want to know how to make
the program acknowledge the presence of the Device.
I gather that if I uninstall the audio drivers, and restart the machine, XP
will attempt to install the audio card's drivers. When I try to delete the
drivers for the sound, their are several other drivers still present, called,
audio Codecs, Legacy Audio Driver, Media Control Devices. These I cannot
uninstall. So I restart the machine, XP sees the unsupported hardware,
installs the drivers, but I still get the "No Audio Device Installed"
message. That is, no change from the previous position. And still no sound.
So, where do you get the idea I don't know how to download drivers or
install them? If you don't know an answer to the question I asked, which was
"Is there some way to fix this without doing a reformat and re install", just
be quiet and eat your cookie.
Is there an adult out there who can answer my question?
John Masterson
> Bat,
> else can.
> hardware.
> Ron J
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > NO SOUND!
There are 1217 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
