Tom's Hardware > Forum > Mobile Computing > General Mobile Computing > Can you put these in order of speed?
Forum Mobile Computing : General Mobile Computing - Can you put these in order of speed?
All mobile chips
A = 2.6Ghz Athlon XP-M
B = 1.3Ghz Centrino
C = 2.6Ghz P4
Cheers.
Sponsored Links
There's an Athlon with an real clock speed of 2.6ghz?
Or are you talking about the PR rating of 2600+ ??
If thats the case, than the 2600+ is really around 2.08ghz
~m0j0
Reply to Uber_m0j0
fastest - C
medium - B
slowest - A
Reply to blueedge
Wow the athlons are that bad? I was under the impression that the 2600+ would probably be equal to centrino 1.4ghz or so...
Reply to ClayMan
The athlon 2600+ has a lower clock speed but is more effective and therfore performs as well as a P4 2.6, why else do you think they gave it that name?
As for the centrino is should be about as fast as a P4 2.2 so that would make it:
C/A (it all depends on the actions and athlon has no HT, altough that is hard to find in P4's in laptops)
B
If all else fails: Read The Manual
Reply to toxicogen
Quote :
B
Quote :
Intel does have P4m cpu's with HT enabled.
I was not aware they had released HT enabled P4m processors.
Intel has two varities of P4m processors.
The ones with HT enabled are:
3.20 GHz, 3.06 GHz, 2.80 GHz, 2.66 GHz
The ones without HT enabled are:
3.06 GHz, 2.80 GHz, 2.66 GHz, 2.40 GHz
See this <A HREF="http://forumz.tomshardware.com/mobile/modules.php?name=Forums&file=viewtopic&p=3668#3668" target="_new">thread </A>
<b> “Liberals have many tails and chase them all.” – H.L. Mencken <b>
Reply to Jake_Barnes
Fastest is definitely "C"/"A" (dependant on task), with the slowest being "B".
RaPTuRe
Who's General Failure and why's he reading my disk?
Reply to RaPTuRe
These are actually "mobile" P4's rather than P4-m. The distiction is that the P4-m's are all 400MHz bus chips up to 2.6GHz and dissipate only 35W, whereas the "mobile" chips are desktop chips with minimal power management which run with 533 and 800MHz buses, with/without HT and dissipate from 50 to 80W.
Wooly
Reply to WoolyMammoth
There are 1154 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
