"James" <rotoquad@***NOSPAMTHANKS***earthlink.net> wrote in message
news:qLlVd.3$nb1.2@tattler.gsu.edu...
> The manual does not have it, I see earlier posts that others were looking
> and in one case a link was provided, but it is now dead.
> Does anyone have one? Thanks.
> Reply To: james at retroblast dot com
Archived from groups: rec.games.video.arcade,rec.games.video.arcade.collecting (More info?)
complete....forgot to cross my t's
doh )
"Pepelepew" <pepelepew9@worldnet.att.net> wrote in message
newsYtVd.95162$Th1.15129@bgtnsc04-news.ops.worldnet.att.net...
> Try this,
> not sure if its comple
> http://arcarc.xmission.com/PDF%20A [...] chematics/ > Rick
looking
Munged emails piss me RTFO - I was going to email you and offer a photocopy
mailed at no charge of the proper schematic, but it simply wasnt worth the
effort
Art
Art,
Thanks for the attempted offer. Sorry about the email, but I just get
hammered with spam. I think I go what I needed though so I don't think it
will be required. Thanks again.
James
"Art Mallet - Artfromny - formerly A218@aol.com" <artgames@nycap.rr.com>
wrote in message news:ugvVd.35443$vK5.31763@twister.nyroc.rr.com...
photocopy
> effort
> Art
looking
I read all your post and what I have done in the past with all my MCR
systems is buy a
switching power supply with adapter
it will cost you around$80.00 and it sure cures alot of problems and
prevents alot of problems.
Those MCR boards are very picky about their voltage and the VBat and Reset
voltage coming from
the power supply board.
Tron PCBs are a piece of cake to repair. If you want to shotgun them,
change the 2 pots, the 2n3055 pass transistor, the little tantalum lytic in
the center of the board, and go from there. Word of advice - the comparator
IC in the 5 volt line often seems like the problem, bit rarely is.
Art
"Rob" <rrandal@pacbell.net> wrote in message
news:z0FVd.8811$OU1.6234@newssvr21.news.prodigy.com...
> systems is buy a
> voltage coming from
heh...here is how I read alot of that....
Tron PCBs sind ein Stück zu reparieren des Kuchens. Wenn Sie zur
Schrotflinte sie wünschen, ändern Sie die 2 Töpfe, den Transistor des
Durchlaufs 2n3055, das wenige Tantal, das in der Mitte des Brettes, lytisch
ist und gehen Sie von dort. Wort des Rates - die Komparator IS in der
5-Volt-Linie scheint häufig wie das Problem, Spitze ist selten.
wrote in message news:TrFVd.35742$vK5.6394@twister.nyroc.rr.com...
in
comparator
> Art
> > systems is buy a
Reset
> > voltage coming from
looking
Ahhh, that's because Tron is French for Piece of ..... You should have
read:
Des Tron PCBs sont un morceau réparer le gâteau. Si vous la souhaitez
au canon de grenaille, vous modifiez les 2 pots, le transistor de la
course 2n3055, peu de le tantale qui est dans le milieu du panneau,
lytisch et vous allez de là-bas. Mot du conseil - le comparateur le IS
le 5-Volt-Linie semble, un dessus est fréquemment comme le problème rare.
which of course means:
Of Tron PCBs are a piece to repair the cake. If you wish it with the
gun of shot, you modify the 2 pots, the transistor of the race 2n3055,
little the tantalum which is in the medium of the panel, lytisch and you
go from over there. Word of the council - the comparator the IS the
5-Volt-Linie seems, a top is frequently like the rare problem.
Hope that helps.
Pat D.
> in
> comparator
>>Art
>>>systems is buy a
> Reset
>>>voltage coming from
> looking
"Triznon PCBs is a piece of cakes ta repair bitch. If you want ta
shotgun thizzem,
change tha 2 pizzots, tha 2n3055 pass transistor, tha shawty tantalum lytic
in
the poser of tha board, n go from there . Put ya mutha f'in choppers up if
ya feel this..
Word of advice - tha comparizzles IC in tha 5 volt line often seems like tha
problem, bit rarely is. "
nope....still confused
"Pat D" <patdanis@comcast.net> wrote in message
news:y82dnYxPlpqFFbrfRVn-2A@comcast.com...
> read:
> Hope that helps.
> Pat D.
lytisch
> > in
> > comparator
> >>Art
> >>>systems is buy a
> > Reset
> >>>voltage coming from
> > looking
shotgun thizzem,
in
ya feel this..
> read:
> Hope that helps.
> Pat D.
lytisch
> > in
> > comparator
> >>Art
> >>>systems is buy a
> > Reset
> >>>voltage coming from
> > looking
