Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I have tried to migrate an XP installtion to a new disk from a failing one.
The problem is that the drive letter of the partition keeps resetting to D:
drive even though it was the L: drive. ( fourth primary partition on disk
2 ).
This results in code 0x80090006 Unable to acquire licence info and the
automatic forced loggin off of the system . If the partition resets to D: I
will have to reinstall all applications and rebuild the links on about 40 gb
of files an programs because everything but C: will have changed.
Any idea as to how to stop XP from rearranging drive letters or resolve the
error to log in and fix locally ???
You can change the drive letter from D to L in Disk Management or Partition
Magic. Otherwise you could run DriveMapper in Partition Magic but the former
choice is better.
Brian
"Ian Marsh" <ianmarshREMOVECAPSANDNOSPAM@nospam.istop.com> wrote in message
news:e9PlifDMFHA.3320@TK2MSFTNGP15.phx.gbl...
> D:
> 2 ).
> I
> gb
> the
If the O/S was on drive/partition L: to begin with (fourth primary partition
on disk 2) then you will have to place it in the same relative position
(fourth primary partition on disk 2) to have it boot. Place it on another
drive/partition and you will have to perform a repair install.
Windows XP is drive/position sensitive. This is why many of those in the
know make certain that the O/S is installed in the first partition on the
master drive which is connected to the primary IDE controller. If you want
to install to any other existing drives or partitions you must choose the
appropriate drive/partition and choose to format prior to install (for a
clean install). Note that even then, some critical files will be placed on
drive/partition C: - wherever it may be. If you later format or delete the
original C: partition your operating system will become unbootable.
The best way to install is by booting from the Windows XP CD. When you get
to the screen where you chose where to install the O/S you are presented
with a clear representation of what is already on your computer.
If another drive/partition is already claiming C: as it's own, your options
will be limited. You can install there anyway and hope for the best (not a
good choice). You can format the partition (don't delete it first) and do a
clean install - and lose all information in the process. You can delete the
old partition, create a new one and then format it. The new partition likely
WILL NOT be labeled C: (depending upon the present drive/partition geometry)
Example: If drives/partitions C: through R: are already used, and you want
to install on other free space, you will likely end up with drive/partition
S:, or some other designation.
Reading up on how a computer handles drive letters and partition letters
(primary DOS partition - extended partition - logical partitions etc) on
multiple drives will greatly help you to overcome these obstacles and
limitations. The relationships and interactions can be intimidating.
The help section and manual that come with Partition Magic is particularly
helpful in this respect!
I guess that this is why major manufacturers use just one partition on the
computers they deliver to their customers. It is also why the recovery
options shipped with many new computers will wipe the entire drive, even
though you just want to work with partition C:. Otherwise support would be a
nightmare!
It is the reason why so many people here advocate for the same method. It
can be confusing and difficult to properly implement, unless you are
starting from scratch - read as clean drives with no partitions at all.
Regards,
Richard Urban
aka Crusty (-: Old B@stard :-)
If you knew as much as you think you know,
You would realize that you don't know what you thought you knew!
> D:
> 2 ).
> I
> gb
> the
I guess that's why I am confused. I did match position and type on the disk.
(All four partitions)
The machine had Windows 98 on C: with not enough room to install XP, so L:
it was.
I matched exact positions moving the four partitions over.
Part of the problem I guess is that Ghost is no longer Ghost. ( I resent
paying $150
for a new version of a product only to find it's not the product but a
substitute.)
Older versions of ghost, you boot a diskette and copy partition to
partition, without a
glitch (because it is a byte for byte imagese). The new version is extremely
tied to the
existing operating system using .Net.and requires Windows XP be running. I
don't know
if this is Partition Magic ( I know Symantec bought it ) but whatever it is
it's not straighforward.
I will see what's in the manual for Ghost but I only have the softcopy
.....and my first browsing
found nothing ....
64 Dollar - question which version of Partition Magic if not the Ghost
version ???
"Richard Urban" <richardurbanREMOVETHIS@hotmail.com> wrote in message
newsG5o$4GMFHA.3500@TK2MSFTNGP14.phx.gbl...
partition
options
a
the
likely
geometry)
drive/partition
a
> nightmare!
> Regards,
> Richard Urban
message
one.
> > D:
disk
> > 2 ).
D:
> > I
40
> > gb
> > the
Partition Magic and Ghost are two entirely different products.
The current version of Partition Magic is 8.01
The current version of Ghost is 9.0.2.3981
I use a combination of the two to do exactly what you want to do.
Regards,
Richard Urban
news:eu6dIvJMFHA.4028@tk2msftngp13.phx.gbl...
>disk.
> it was.
> paying $150
> substitute.)
> extremely
> tied to the
> I
> don't know
> is
> found nothing ....
> version ???
> partition
>> want
>> on
>> the
>> get
> options
>> a
> a
> the
> likely
> geometry)
>> want
> drive/partition
>> particularly
>> the
>> be
> a
>> nightmare!
>> Regards,
>> Richard Urban
> message
> one.
>> > to
>> > D:
> disk
>> > 2 ).
> D:
>> > I
> 40
>> > gb
>> > the
Richard, Norton Partition Magic is now 8.05.
Brian
news:uxGm0KLMFHA.2464@TK2MSFTNGP10.phx.gbl...
Only if you buy new apparently!
They will not update 8.01 to version 8.05. Cheap f***s. I have had every
version of Partition Magic since version 2 became available. I am not going
to pay again for an "incremental" upgrade.
Regards,
Richard Urban
"Brian K" <iibntgyea4 REMOVE_THIS@hotmail.com> wrote in message
news:erGG3ZLMFHA.3336@TK2MSFTNGP10.phx.gbl...
> Brian
I can't see any changes in 8.05 compared with 8. Incremental as you say.
Brian
news:us1HLgLMFHA.2604@TK2MSFTNGP10.phx.gbl...
> going to pay again for an "incremental" upgrade.
Thanks for that!
Regards,
Richard Urban
news:%23X4cmwLMFHA.3076@TK2MSFTNGP14.phx.gbl...
> Brian
I guess I will have to "shell out". Thanks for your advice and insight.
going
> Regards,
> Richard Urban
> > Brian
