Archived from groups: rec.games.video.arcade (
More info?)
Were the settings accepted ? (eg it returned the coupon immediately and
flashed 10 times) ?
"Kelly Ray" <starwarsroomspam@comcast.net> wrote in message
news:0MednbAandh6LtPfRVn-gw@comcast.com...
> i've been there already(did exactly what you suggested) and did that a
first
> before messing with the dips.
> i thought i might have one setting incorrect but if this is the right
> settings then what else could it be??
> thanks for the info,
> Kelly
> "Felix T Cat" <cfelix2k@NOSPAMgmail.com> wrote in message
> news:rny3e.3188945$Zm5.509019@news.easynews.com...
> > Those are the right settings. If you have ANY dip switches in the ON
> > position it will override the coupon config. Basicly when you use the
> > coupon you are re-configuring the "default" settings in the BV.
> > So, put all switches to the OFF position, press the blue button on the
> > back
> > of the bv and insert the coupon.
> > The BV should return the coupon immediately and the LED should flash 10
> > times.
> > IF the BV holds the coupon for 10 seconds and then returns it the LED
will
> > flash the number of times to correspond to the section of the coupon
that
> > is
> > incorrect. (eg 5 flashes indicates a problem with the bezel lights
> > section)
> > Hope this helps.
> > news:woCdnfT6frXMM9PfRVn-1w@comcast.com...
> >> thanks for the reply!
> >> i have one of these for the 2500 series now and have already used it
and
> >> these are the settings that i have colored in.....are they correct for
my
> >> use?
> >> # of bill directions 4
> >> $1 high accept
> >> $2 high accept
> >> $5 high accept
> >> pulse short(???)
> >> pulses per dollar 4(???)
> >> bezel lights on/flashing F
> >> is this right? i was told that even if you set this, you dips take
> >> precidence over this default setting???
> >> Kelly
> >> news:zzw3e.3182418$Zm5.508189@news.easynews.com...
> >> > The VN was designed for the Vending machines (not amusement machines)
> > That
> >> > is why you have to use the jumper. Now as for the pulses per dollar.
> > The
> >> > AE validator has a switch setting for pulses per dollar, the VN does
> > not.
> >> > The VN standard settings are 1 pulse per dollar.
> >> > The only way to change it is to "coupon config" the validator. The
> > coupon
> >> > is found in the instal guide if you still have it and you just fill
out
> >> > the
> >> > boxes with a #2 pencil. If you don't have it call 800-345-8172
during
> > the
> >> > week and press the buttons for Tech support. They should be able to
> >> > fax
> >> > out
> >> > a coupon to you.
> >> > Important, the AE and VN coupons are different, make sure you get the
> >> > VN
> >> > one.
> >> > news:y-idnTFWEta809PfRVn-iA@comcast.com...
> >> >> i have a Merit Megatouch Sapphire that i replaced a DBA in and have
a
> >> > stupid
> >> >> question about!
> >> >> it is a 2511 U3 VN with a jumper to take new $5 and for amusement
> >> > acceptance
> >> >> which i already have in another Touchmaster touchscreen that works
> > fine.
> >> > my
> >> >> question is probably easy but i am having troubles with making the
$1
> >> >> give
> >> > 4
> >> >> credits and same with $5 giving the correct 20 credits(now gives
> >> >> $1=1cr
> >> > and
> >> >> $5=5cr). menus option somewhere i'm missing????
> >> >> is there an easy solution for my problem? i have went through the
> > menus
> >> >> several times but can't figure out what i need to do!!!
> >> >> TIA,
> >> >> Kelly
