Hi,
can anyone help me with my problem here? My system is win2k, athlon xp 1600, Gainward GeForce ti4200 128 MB Golden sample or somekind like that. When i tried to play ms flight sim my comp restarted w/o reason. Then i played GunBound, the same thing happened. To figure out what is the problem, i run the D3D hardawre accelerator from expert tool (from gainward). I passed the D3D7, but when i tested for the D3d8, my comp restarted. Can someone help me how to solve this problem? Below i post the VGA information from the expert tool.
Thank you very much,
Regards,
Display Devices
Card name: NVIDIA GeForce4 Ti 4200
Manufacturer: NVIDIA
Chip type: GeForce4 Ti 4200
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0253&SUBSYS_160310B0&REV_A3
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (75Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: nv4_disp.dll
Driver Version: 6.13.0010.2980 (English)
DDI Version: 8
Driver Attributes: Final Retail
Driver Date/Size: 5/24/2002 12:42:00, 3539962 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 5/24/2002 12:42:00, 944330 bytes
Device Identifier: {D7B71E3E-4113-11CF-A478-093601C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0253
SubSys ID: 0x160310B0
Revision ID: 0x00A3
Revision ID: 0x00A3
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
[] [_] [--
Regards,
Display Devices
Monitor Max Res:
DDI Version: 8
WHQL Logo'd: No
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x0253
Revision ID: 0x00A3
Revision ID: 0x00A3
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
[] [_] [--
